I download the Ubuntu Classic Server 16.04 - Raspberry Pi 3 from https://ubuntu-pi-flavour-maker.org/download/ and installed it on my RPi 3. Now I see that wlan0 is missing.
I don't have /dev/video0 even-though I have a (flex) camera connected.
So I tried to see if it is a configuration matter, but when executed
sudo raspi-config
I get:
sudo: raspi-config: command not found
Is that the problem? If so, how can I install it?
If not, what else can I try in order to make the camera and wifi module to work?
Aurora0001
  • 6,308
  • 38
Gil404
  • 141
raspi-config is just a front end to the various configuration files - it is a simple bash script (if long and convoluted), and you could copy it from Raspbian, or find on the web.
Whether it would work is doubtful; while most options should work, networking probably won't as Ubuntu uses Network Manager and predictable network interface names so wlan0 won't exist.
raspi-config is now installed on Ubuntu Mate for Pi and this may be different to the Raspbian version.
  • In my case it did not work, since raspi-config expects config.txt and other essential files to be located in /boot folder, but in my Ubuntu xenial installation these files are in /boot/firmware folder – Mikhail Oct 18 '19 at 14:48
