I have a problem with RPi and WiFi channel changing. As I discovered these days - RPi determines channel only during boot procces. And this is an issue. If I log in to my AP (mikrotik) and change frequency to any another - RPi always disapear and does not appear anymore untill one of bellow items becomes true:
- Restoring frequency/channel that was actual on RPi boot time
- RPi reboot.
Details:
RPi: 2 model B
OS: Raspbian Jessie
WiFi: 2.4Ghz 801.11n with SSID hidden
I want to fix this issue and make able autoreestablishing WiFi connection without rebooting RPi, because I use "Channel: auto" on my AP and don't want to disable the feature.
Please help me to fix.
---------------- Additional info ---------------------
cat /etc/network/interfaces | egrep -v "^\#"
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
cat /etc/wpa_supplicant/wpa_supplicant.conf
country=US
update_config=1
network={
   ssid="SSID"
   psk="PWD"
   bssid=XX:XX:XX:XX:XX:XX
   scan_ssid=1
   proto=WPA2          # can be RSN (for WPA2) or WPA (for WPA1)
   key_mgmt=WPA-PSK    # can be WPA-PSK or WPA_EAP (for enterprise networks)
   pairwise=CCMP       # can be CCMP( for WPA2) or TKIP (for WPA1), or both
   auth_alg=OPEN       # can be OPEN, LEAP and SHARED
/etc/network/interfacesand/etc/wpa_supplicant/wpa_supplicant.conf? – oh.dae.su Jul 11 '18 at 09:59
