I've followed this post :
How to auto start chromium after boot on the Raspberry 2 (2015-01-31 debian wheezy)?
I've added the two following lines to the autostart file referenced there
/usr/bin/chromium-browser
/usr/bin/ekiga
Both those commands work from the terminal but nothing on startup.
Two questions arise from this.
  • Any thoughts on why it isn't working
  • How can I monitor/log/track what may or may not be working with this?
Patrick
  • 121
to get Chromium and ekiga to start at login on a per user basis I needed to do the following
> nano /home/user/.config/lxsession/LXDE-pi/autostart
then add the following lines:
@/usr/bin/chromium-browser --command-line-options
@/usr/bin/ekiga
Patrick
  • 121
Do you use a distro with installed LXDE? Otherwise this autostart file location is wrong.
LXDE/KDE/Gnome all are different, what desktop enviroment did you use?
(you can even try to use cron via crontab for this with the @reboot flag)
Broatcast
  • I'm just using stock raspbian. The file /LXDE-pi/autostart already existed and had entries in it (eg @lxpanel --profile LXDE-pi) so I assumed that LXDE was already there. – Patrick Jun 20 '18 at 10:19
