Users often seem confused about what Pi model they have and what OS version is installed or how to find details.
Where is this located?
The following script is one I use including the following commands to collect relevant details. (It is called aboutpi)
Download latest from https://github.com/Milliways2/Raspberry-Pi-Utilities/blob/main/aboutpi
#! /bin/sh
# 2024-01-30    No LSB modules are available.
# Function to print coloured headings
#  delete "tput" lines for plain output
print_head () {
 tput setaf 6
 echo $1
 tput sgr 0
if [ -e /etc/rpi-issue ]; then print_head "- Original Installation" cat /etc/rpi-issue | grep reference fi
if [ -e /usr/bin/lsb_release ]; then print_head "- Current OS" lsb_release -irdc | sed 's/No LSB modules are available.//' cat /etc/debian_version fi if [ ! -e /usr/share/xsessions ]; then print_head "X NOT installed" fi print_head "- Kernel" uname -r print_head "- Architecture" uname -m
print_head "- Model" cat /proc/device-tree/model && echo
print_head "- hostname" hostname print_head "- Network" hostname -I
Check status of networking
checkactive () { if [ $(systemctl is-active $1) = 'active' ]; then echo $1 'active' fi } checkactive 'systemd-networkd' checkactive 'dhcpcd' checkactive 'NetworkManager'
Get SSID of connected WiFi (WRONG if AP!)
if [ -e /sys/class/net/wlan0 ]; then if [ $(systemctl is-active 'NetworkManager') = 'active' ]; then nmcli connection show | awk '/wlan0/ {print $1}' else wpa_cli -i wlan0 status | grep -w ssid | awk -F'[=]' '{print $2}' fi fi
sudo fdisk -l /dev/mmcblk0 | grep "Disk identifier"
CPUID=$(awk '/Serial/ {print $3}' /proc/cpuinfo | cut -c 9-)
CPUID=$(vcgencmd otp_dump | grep 28: | cut -c4-)
echo "Serial: " $CPUID if [ -e /opt/vc/bin/vcgencmd -o /usr/bin/vcgencmd ]; then
VERS=$(vcgencmd version | grep ":")
VERS=$(sudo vcgencmd version  | grep ":")
print_head "- Firmware"
echo $VERS
fi print_head "- Created" sudo tune2fs -l $(mount -v | awk '/ on / / {print $1}') | grep created
To list the initial installation (Raspbian only) cat /etc/rpi-issue | grep reference
Raspberry Pi reference 2019-06-20
To list the Current OS lsb_release -irdc
Distributor ID: Raspbian
Description:    Raspbian GNU/Linux 10 (buster)
Release:    10
Codename:   buster
To list the Kernel version uname -r
4.19.58-v7l+
To list the Model cat /proc/device-tree/model
Raspberry Pi 4 Model B Rev 1.1
There are a number of other interesting data:-
To list the hostname hostname
MilliwaysPi4
To list the Firmware /opt/vc/bin/vcgencmd version
Jul  9 2019 14:37:58
Copyright (c) 2012 Broadcom
version d2b1b7fb01475cb3914b2086299e32d724e832f1 (clean) (release) (start)
To list the date the File System was "created" sudo tune2fs -l /dev/mmcblk0p2 | grep created (only for Raspbian on SD Card, but could be modified for other)
Filesystem created:       Fri Jun 21 03:05:22 2019
Output on Raspberry Pi OS (64bit) Pi4B
Raspberry Pi reference 2022-01-28
- Current OS
Distributor ID: Debian
Description:    Debian GNU/Linux 11 (bullseye)
Release:    11
Codename:   bullseye
11.7
- Kernel
6.1.21-v8+
- Architecture
aarch64
- Model
- hostname
MilliwaysPi4
- Network
10.1.2.74 10.1.2.84
NetworkManager active
WiFi-B13A
Disk identifier: 0x2f89a8c6
Serial:  46c9fdae
- Firmware
Mar 17 2023 10:50:39
- Created
Filesystem created:       Fri Jan 20 12:46:02 2023
Output on Raspberry Pi OS Pi3B
Raspberry Pi reference 2021-10-30
- Current OS
Description:    Raspbian GNU/Linux 11 (bullseye)
Release:    11
Codename:   bullseye
11.6
- Kernel
6.1.21-v7+
- Architecture
armv7l
- Model
Raspberry Pi 3 Model B Plus Rev 1.3
- hostname
MilliwaysPi3p
- Network
10.1.2.88
dhcpcd active
WiFi-B13A-5G
Disk identifier: 0xff635d64
Serial:  519c72e8
- Firmware
Mar 17 2023 10:52:42
- Created
Filesystem created:       Sun Jan 29 12:34:01 2023
The output on my Pi3A+ shows
- Current OS
Release:    11
Codename:   bullseye
11.6
X NOT installed
- Kernel
6.1.21-v7+
- Architecture
armv7l
- Model
Raspberry Pi 3 Model A Plus Rev 1.0
- hostname
MilliwaysPi3A
- Network
10.1.2.93
systemd-networkd active
WiFi-B13A
Disk identifier: 0xb5d2de0f
Serial:  f4e430a6
- Firmware
- Created
Filesystem created:       Sat Aug  8 04:32:43 2020
  • Reminds me of the old SysInternals windows program bginfo - tempted to create a little Python program to hack the desktop :-). Bookmarked. –  Mar 24 '20 at 15:02
A "quick and dirty" answer to the question follows. All can be entered from the command line interface:
  1. cat /etc/os-release # provides NAMES, VERSIONS & some URLs for support
  2. lsb_release -a # distribution-specific information; ref man lsb_release
  3. hostnamectl # brief & useful incl hostname, OS ver, kernel ver; ref man hostnamectl
And as if you needed more, this command provides a terse summary with several options to get a specific item - which is useful in scripts to check version dependencies, etc. See man uname for details, and for example, the kernel version can be had as follows:
  1. uname -r
Credits to nixCraft for the most complete answer I could find.
Seamus
  • 21,900
  • 70
