I've started my Raspberry Pi Model B without having any monitor plugged. Then I plugged the HDMI monitor, but got no signal. So far I've been able to turn it on by using the command:
tvservice --preferred
But it only turns the monitor on and sets the preferred display mode, while the screen is still blank. I've then been able to reset to low-resolution console by starting Xorg with the command
startx /usr/bin/lxterminal
(which runs in low resolution itself) and then just typed exit into the terminal.
The problem is that the resulting console is still low-resolution, and the way I got it is far from being elegant.
How can I get the native-resolution console after booting up without monitor, without rebooting?
Ruslan
  • 175
After some more searching I've found the solution:
  1. tvservice --preferred (monitor turns on)
  2. Alt+F2, Alt+F1 to switch to VT2 and back to VT1 (console text appears)
  3. fbset -g 1920 1080 1920 1080 32 (resolution becomes 1920x1080)
Thanks to this answer.
Ruslan
  • 175
