I need to configure wifi-eathernet bridge for my IP cameras net. I've tried to use this tutorial: Sharing the Pi's WiFi connection through the Ethernet port, to resolve my issue and experienced another one. When I try to start dnsmasq as sudo systemctl start dnsmsq the error occured. Here is the code:
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: failed (Result: resources) since Tue 2018-06-12 14:01:24 UTC; 44s ago
Process: 1072 ExecStop=/etc/init.d/dnsmasq systemd-stop-resolvconf (code=exited, status=0/SUCCESS)
Process: 1069 ExecStartPost=/etc/init.d/dnsmasq systemd-start-resolvconf (code=exited, status=0/SUCCESS)
Process: 1067 ExecStart=/etc/init.d/dnsmasq systemd-exec (code=exited, status=0/SUCCESS)
Process: 1064 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=0/SUCCESS)
Also, here is sudo journalctl -u dnsmasq.service result:
-- Logs begin at Tue 2018-06-12 14:01:03 UTC, end at Tue 2018-06-12 14:41:02 UTC. --
Jun 12 14:01:07 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Jun 12 14:01:07 raspberrypi dnsmasq[445]: dnsmasq: syntax check OK.
Jun 12 14:01:07 raspberrypi systemd[1]: PID file /var/run/dnsmasq/dnsmasq.pid not readable (yet?) after start-post.
Jun 12 14:01:08 raspberrypi systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Jun 12 14:01:08 raspberrypi systemd[1]: Unit dnsmasq.service entered failed state.
Jun 12 14:01:24 raspberrypi systemd[1]: Stopped dnsmasq - A lightweight DHCP and caching DNS server.
Jun 12 14:01:24 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Jun 12 14:01:24 raspberrypi dnsmasq[1064]: dnsmasq: syntax check OK.
Jun 12 14:01:24 raspberrypi systemd[1]: PID file /var/run/dnsmasq/dnsmasq.pid not readable (yet?) after start-post.
Jun 12 14:01:24 raspberrypi systemd[1]: Failed to start dnsmasq - A lightweight DHCP and caching DNS server.
Jun 12 14:01:24 raspberrypi systemd[1]: Unit dnsmasq.service entered failed state.
Result: resources - not a very informative message. Could you please help me with this.
Here are all configuration:
/etc/dnsmasq.conf
interface=eth0
listen-address=172.24.2.1
bind-interfaces
server=8.8.8.8
domain-needed
bogus-priv
dhcp-range=172.24.2.50,172.24.2.60,12h
/etc/iptables.ipv4.nat
# Generated by iptables-save v1.4.21 on Tue Jun 12 11:45:00 2018
*filter
:INPUT ACCEPT [1:76]
:FORWARD ACCEPT [0:0]
:OUTPUT ACCEPT [1:76]
-A FORWARD -i wlan0 -o eth0 -m state --state RELATED,ESTABLISHED -j ACCEPT
-A FORWARD -i eth0 -o wlan0 -j ACCEPT
COMMIT
# Completed on Tue Jun 12 11:45:00 2018
*nat
:PREROUTING ACCEPT [0:0]
:INPUT ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
-A POSTROUTING -o wlan0 -j MASQUERADE
COMMIT
/etc/network/interfaces
auto lo
iface lo inet loopback
# iface eth0 inet manual
allow-hotlug eth0
iface eth0 inet static
address 172.24.2.1
netmask 255.255.255.0
network 172.24.2.0
broadcast 172.24.2.255
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
/proc/sys/net/ipv4/ip_forward
Thanks in advance!
? If so, it might be helpful to [edit] the output into your post. – Aurora0001 Jun 12 '18 at 14:35pi@raspberrypi:~ $ journalctl -u dnsmasq.service No journal files were found.
– Taras Mykhalevych Jun 12 '18 at 14:38sudo journalctl -u dnsmasq.service
); apparently that's systemd's way of telling you that you haven't got privileges! – Aurora0001 Jun 12 '18 at 14:40
