I'm trying to connect form my laptop to my pi with ssh but i get Permission denied, when insert the password.
I do: ssh pigio@192.168.178.79
- I'm sure the ip address is correct because i can PING and get response.
- I'm quite sure the password i'm typing is the same (keyboard layout) because i type on note pad on both machine so i can see it and look the same.
- i can connect with ssh from my pi to the pi with
ssh localhost, inserting the password that i note down. - i edit my network from
/etc/wpa_supplicant/wpa_supplicant.confbut it didn't connect, so i then connect with wifi OS settings. The configuration on thewpa_supplicant.conffile is still there, tho.
I'm in wlan (yes, same network), raspberry pi 3, mac last OS.
Is there anything else i can try to debug or see why it wouldn't work?
UPDATE: Look like RSP has issue to naturally connect to 5Ghz network. Or maybe just with dual band network. Could someone confirm this? There is any relativly simple solutions for Mac?
UPDATE 2 Ping result:
PING 192.168.178.79 (192.168.178.79): 56 data bytes
64 bytes from 192.168.178.79: icmp_seq=0 ttl=64 time=18.553 ms
64 bytes from 192.168.178.79: icmp_seq=1 ttl=64 time=33.489 ms
ssh -vvv pigio@192.168.178.79 -p 22
OpenSSH_7.6p1, LibreSSL 2.6.2
debug1: Reading configuration data /etc/ssh/ssh_config
debug1: /etc/ssh/ssh_config line 48: Applying options for *
debug2: ssh_connect_direct: needpriv 0
debug1: Connecting to 192.168.178.79 port 22.
debug1: Connection established.
debug1: identity file /Users/anaketa/.ssh/id_rsa type 0
debug1: key_load_public: No such file or directory
debug1: identity file /Users/anaketa/.ssh/id_rsa-cert type -1
debug1: identity file /Users/anaketa/.ssh/id_dsa type -1
debug1: identity file /Users/anaketa/.ssh/id_dsa-cert type -1
debug1: identity file /Users/anaketa/.ssh/id_ecdsa type -1
debug1: identity file /Users/anaketa/.ssh/id_ecdsa-cert type -1
debug1: identity file /Users/anaketa/.ssh/id_ed25519 type -1
debug1: identity file /Users/anaketa/.ssh/id_ed25519-cert type -1
debug1: Local version string SSH-2.0-OpenSSH_7.6
debug1: Remote protocol version 2.0, remote software version OpenSSH_7.4p1 Raspbian-10+deb9u3
debug1: match: OpenSSH_7.4p1 Raspbian-10+deb9u3 pat OpenSSH* compat 0x04000000
debug3: fd 5 is O_NONBLOCK
debug1: Authenticating to 192.168.178.79:22 as 'pigio'
debug3: hostkeys_foreach: reading file "/Users/anaketa/.ssh/known_hosts"
debug3: record_hostkey: found key type ECDSA in file /Users/anaketa/.ssh/known_hosts:32
debug3: load_hostkeys: loaded 1 keys from 192.168.178.79
debug3: order_hostkeyalgs: prefer hostkeyalgs: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521
debug3: send packet: type 20
debug1: SSH2_MSG_KEXINIT sent
debug3: receive packet: type 20
debug1: SSH2_MSG_KEXINIT received
debug2: local client KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group-exchange-sha1,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1,ext-info-c
debug2: host key algorithms: ecdsa-sha2-nistp256-cert-v01@openssh.com,ecdsa-sha2-nistp384-cert-v01@openssh.com,ecdsa-sha2-nistp521-cert-v01@openssh.com,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521,ssh-ed25519-cert-v01@openssh.com,ssh-rsa-cert-v01@openssh.com,ssh-ed25519,rsa-sha2-512,rsa-sha2-256,ssh-rsa
debug2: ciphers ctos: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: ciphers stoc: chacha20-poly1305@openssh.com,aes128-ctr,aes192-ctr,aes256-ctr,aes128-gcm@openssh.com,aes256-gcm@openssh.com
debug2: MACs ctos: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: MACs stoc: umac-64-etm@openssh.com,umac-128-etm@openssh.com,hmac-sha2-256-etm@openssh.com,hmac-sha2-512-etm@openssh.com,hmac-sha1-etm@openssh.com,umac-64@openssh.com,umac-128@openssh.com,hmac-sha2-256,hmac-sha2-512,hmac-sha1
debug2: compression ctos: none,zlib@openssh.com,zlib
debug2: compression stoc: none,zlib@openssh.com,zlib
debug2: languages ctos:
debug2: languages stoc:
debug2: first_kex_follows 0
debug2: reserved 0
debug2: peer server KEXINIT proposal
debug2: KEX algorithms: curve25519-sha256,curve25519-sha256@libssh.org,ecdh-sha2-nistp256,ecdh-sha2-nistp384,ecdh-sha2-nistp521,diffie-hellman-group-exchange-sha256,diffie-hellman-group16-sha512,diffie-hellman-group18-sha512,diffie-hellman-group14-sha256,diffie-hellman-group14-sha1
debug2: host key algorithms: ssh-rsa,rsa-sha2-512,rsa-sha2-256,ecdsa-sha2-nistp256,ssh-ed25519
debug2: reserved 0
debug1: kex: algorithm: curve25519-sha256
debug1: kex: host key algorithm: ecdsa-sha2-nistp256
debug1: kex: server->client cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug1: kex: client->server cipher: chacha20-poly1305@openssh.com MAC: <implicit> compression: none
debug3: send packet: type 30
debug1: expecting SSH2_MSG_KEX_ECDH_REPLY
debug3: receive packet: type 31
debug1: Server host key: ecdsa-sha2-nistp256 SHA256:tO/pT+gnUbIvtAaoh7xaxp6jrQlz1X6hS4PMw6ZEFRQ
debug1: Host '192.168.178.79' is known and matches the ECDSA host key.
debug1: Found key in /Users/anaketa/.ssh/known_hosts:32
debug3: send packet: type 21
debug2: set_newkeys: mode 1
debug1: rekey after 134217728 blocks
debug1: SSH2_MSG_NEWKEYS sent
debug1: expecting SSH2_MSG_NEWKEYS
debug3: receive packet: type 21
debug1: SSH2_MSG_NEWKEYS received
debug2: set_newkeys: mode 0
debug2: key: /Users/anaketa/.ssh/id_rsa (0x7fbac6d0a3d0)
debug2: key: /Users/anaketa/.ssh/id_dsa (0x0)
debug2: key: /Users/anaketa/.ssh/id_ecdsa (0x0)
debug2: key: /Users/anaketa/.ssh/id_ed25519 (0x0)
debug3: send packet: type 5
debug3: receive packet: type 7
debug1: SSH2_MSG_EXT_INFO received
debug1: kex_input_ext_info: server-sig-algs=<ssh-ed25519,ssh-rsa,ssh-dss,ecdsa-sha2-nistp256,ecdsa-sha2-nistp384,ecdsa-sha2-nistp521>
debug3: receive packet: type 6
debug2: service_accept: ssh-userauth
debug1: SSH2_MSG_SERVICE_ACCEPT received
debug3: send packet: type 50
debug3: receive packet: type 51
debug1: Authentications that can continue: publickey,password
debug3: start over, passed a different list publickey,password
debug3: preferred publickey,keyboard-interactive,password
debug3: authmethod_lookup publickey
debug3: remaining preferred: keyboard-interactive,password
debug3: authmethod_is_enabled publickey
debug1: Next authentication method: publickey
debug1: Offering public key: RSA SHA256:wAWUzMySNDUJjmwLlmPkkRvfwzyTF+LMGQTKtWtQaP4 /Users/anaketa/.ssh/id_rsa
debug3: send_pubkey_test
debug2: we sent a publickey packet, wait for reply
debug1: Trying private key: /Users/anaketa/.ssh/id_dsa
debug3: no such identity: /Users/anaketa/.ssh/id_dsa: No such file or directory
debug1: Trying private key: /Users/anaketa/.ssh/id_ecdsa
debug3: no such identity: /Users/anaketa/.ssh/id_ecdsa: No such file or directory
debug1: Trying private key: /Users/anaketa/.ssh/id_ed25519
debug3: no such identity: /Users/anaketa/.ssh/id_ed25519: No such file or directory
debug2: we did not send a packet, disable method
debug3: authmethod_lookup password
debug3: remaining preferred: ,password
debug3: authmethod_is_enabled password
debug1: Next authentication method: password
pigio@192.168.178.79's password:
debug2: we sent a password packet, wait for reply
Permission denied, please try again.
debug1: No more authentication methods to try.
pigio@192.168.178.79: Permission denied (publickey,password).
@Fabian I post the log as new answer because is too long and it doesnt allow me to post it:
Log of pigio, logged in as pi:
Jun 10 21:34:13 pigio sshd[1086]: Invalid user pigio from
192.168.178.70 port 56997
Jun 10 21:34:13 pigio sshd[1086]: input_userauth_request: invalid user pigio [preauth]
Jun 10 21:34:16 pigio sshd[1086]: pam_unix(sshd:auth): check pass; user unknown
Jun 10 21:34:16 pigio sshd[1086]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=192.168.178.70
Jun 10 21:34:18 pigio sshd[1086]: Failed password for invalid user pigio from 192.168.178.70 port 56997 ssh2
Jun 10 21:34:21 pigio sshd[1086]: pam_unix(sshd:auth): check pass; user unknown
Jun 10 21:34:23 pigio sshd[1086]: Failed password for invalid user pigio from 192.168.178.70 port 56997 ssh2
Jun 10 21:34:25 pigio sshd[1086]: pam_unix(sshd:auth): check pass; user unknown
Jun 10 21:34:27 pigio sshd[1086]: Failed password for invalid user pigio from 192.168.178.70 port 56997 ssh2
Jun 10 21:34:28 pigio sshd[1086]: Connection closed by 192.168.178.70 port 56997 [preauth]
Jun 10 21:34:28 pigio sshd[1086]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=192.168.178.70
Jun 10 21:34:47 pigio sshd[1109]: Invalid user pigio from 192.168.178.70 port 57000
Jun 10 21:34:47 pigio sshd[1109]: input_userauth_request: invalid user pigio [preauth]
Jun 10 21:34:50 pigio sshd[1109]: pam_unix(sshd:auth): check pass; user unknown
Jun 10 21:34:50 pigio sshd[1109]: pam_unix(sshd:auth): authentication failure; logname= uid=0 euid=0 tty=ssh ruser= rhost=192.168.178.70
Jun 10 21:34:53 pigio sshd[1109]: Failed password for invalid user pigio from 192.168.178.70 port 57000 ssh2
Jun 10 21:34:55 pigio sshd[1109]: pam_unix(sshd:auth): check pass; user unknown
Jun 10 21:34:57 pigio sshd[1109]: Failed password for invalid user pigio from 192.168.178.70 port 57000 ssh2
Jun 10 21:34:59 pigio sshd[1109]: pam_unix(sshd:auth): check pass; user unknown
Jun 10 21:35:01 pigio sshd[1109]: Failed password for invalid user pigio from 192.168.178.70 port 57000 ssh2
Jun 10 21:35:02 pigio sshd[1109]: Connection closed by 192.168.178.70 port 57000 [preauth]
Jun 10 21:35:02 pigio sshd[1109]: PAM 2 more authentication failures; logname= uid=0 euid=0 tty=ssh ruser= rhost=192.168.178.70
Jun 10 21:35:35 pigio systemd-logind[343]: New seat seat0.
Jun 10 21:35:36 pigio sshd[450]: Server listening on 0.0.0.0 port 22.
Jun 10 21:35:36 pigio sshd[450]: Server listening on :: port 22.
Jun 10 21:35:39 pigio lightdm: pam_unix(lightdm-autologin:session): session opened for user pi by (uid=0)
Jun 10 21:35:39 pigio systemd-logind[343]: New session c1 of user pi.
Jun 10 21:35:39 pigio systemd: pam_unix(systemd-user:session): session opened for user pi by (uid=0)
Jun 10 21:35:41 pigio login[442]: pam_unix(login:session): session opened for user pi by LOGIN(uid=0)
Jun 10 21:35:41 pigio systemd-logind[343]: New session c2 of user pi.
Jun 10 21:35:42 pigio polkitd(authority=local): Registered Authentication Agent for unix-session:c1 (system bus name :1.14 [lxpolkit], object path /org/freedesktop/PolicyKit1/AuthenticationAgent, locale en_US.UTF-8)
Jun 13 19:43:51 pigio sshd[1019]: Accepted password for pi from 192.168.178.70 port 49273 ssh2
Jun 13 19:43:51 pigio sshd[1019]: pam_unix(sshd:session): session opened for user pi by (uid=0)
Jun 13 19:43:51 pigio systemd-logind[343]: New session c3 of user pi.
/var/log/auth.log| connect usingssh -vvvand set the destination port:ssh -vvv pigio@192.168.1xx.xx -p 22– Fabian Jun 02 '18 at 20:08from my pi to the pi with ssh localhost– Jaromanda X Jun 02 '18 at 23:42auth.log. At least i don't find any if i do/var/log/auth.logssh -vvvgive me normal information about what is happening till i get to the password request. (i'm not home now but i can paste the output later on) I think is the wifi because of the issue you actually post it here https://raspberrypi.stackexchange.com/questions/76617/permission-denied-for-raspbian-default-ssh-password where it saysRaspberry Pi can only connect to 2.4GHz networks.:/ Thank you for your answers btw :) – Giorgia Sambrotta Jun 03 '18 at 16:25
