I want to design a Power Supply Unit(PSU) for Raspbery Pi Zero W. I will have a camera https://www.raspberrypi.org/products/camera-module-v2 connected and running, two relays and few gpio's running.
Camera Consumes around 250mA, RPi idle mode 150mA.
I read here https://www.raspberrypi.org/help/faqs/#power it states Recommended PSU to be 1.2A I can design 5V 1A PSU, will it be sufficient? How to calculate power consumption?
I have read these before but still unclear
Power consumption of Pi Zero W?
https://www.jeffgeerling.com/blogs/jeff-geerling/raspberry-pi-zero-power
If not, could you please share some PSU reference design with inrush | surge protection for 1.2A?
Alan
  • I do not understand how you can design a PSU without knowing the characteristics of the input power. – joan May 31 '18 at 12:34
  • I am really sorry I want to ask how to calculate input power consumption? As recommended by Raspberry Pi, what is Recommended PSU current capacity? How do they recommend then? – Alan May 31 '18 at 12:42
  • You misunderstand. How can you design a PSU without knowing the input voltage and whether it is DC or AC etc? – joan May 31 '18 at 12:46
  • I will be using 220V 50Hz AC source as a power supply – Alan May 31 '18 at 12:51
You sum all parts that consumes power, example:
- Raspberry Pi Z W  230 mA
- Camera            250 mA
- Relay x 2         xxx mA
                    xxx mA
and so on.
The us addition to get the sum of all consumers and that will be the minimum current needed for a PSU. And off course add some leeway
Reference : http://raspi.tv/2017/how-much-power-does-pi-zero-w-use
This is a question for "SE Electrical Engineering".
MatsK
  • 2,791
