I know how to set an static ip. I have 2 configured networks in wpa-supplicant. An i use to use the same static ip in both networks (2 different networks but same wifi range).
The problem is that my static ip is 10.92.x.x and my mobile network i in 192.168.x.x so is not possible to use that. What i want is that when i have that problem i can add a network in wpa_supplicant (My host is under windows 10 and from windows i can't access to /boot), that is the only folder that i can see from windows and then use the dhcp to get ip. Later on i will use ip scanner angry ip or even i will check my phone to check it the ip out.
The question is simple i want to have different networks with different static ips.
Thanks in advance
  • 42,107
  • 85
  • 197
  • Your question is far too vague; How to set up networking/WiFi explains most options. The real issue is WHY you want to use static IP. – Milliways May 09 '18 at 09:55
  • I don't underastan why you don't understand why should i have an static ip in my pi. I am working in a project that involves rfid, raspberry and lamp stack, so i have a web server in my rasp so i need an static ip. The problem is that those days i am havinf some network problems and i want to use my phone as an ap to share my mobile connection with my rasp – Carlos Alberto Calvo Saiz May 09 '18 at 10:13
  • but the problem is that my static ip is 10.92.x.x and my mobile network i in 192.168.x.x so is not possible to use that. What i want is that when i have that problem i can add a network in wpa_supplicant (My host is under windows 10 and from windows i can't access to /boot), that is the only folder that i can see from windows and then use the dhcp to get ip. Later on i will use ip scanner angry ip or even i will check my phone to check it the ip out. @Milliways – Carlos Alberto Calvo Saiz May 09 '18 at 10:13
    you can bind each interface to one network, this is not RPi specific – Fabian May 09 '18 at 18:06
  • What are you asking? "Is it possible to have static ip in a network and dynamic one in other?" or "The question is simple i want to have different networks with different static ips." – Ingo May 09 '18 at 19:15
0 Answers0
