I'm trying to set up an access point with my Pi 3 in order to capture and analyze traffic in a domestic network. I also have connected a Philips Hue bridge to the Raspberry via ehternet. The raspberry here simulates a standard wifi router.
At the moment, both my laptop and the bridge seem to be connected to the network (192.168.4.0/24) with IPs 192.168.4.16 and 192.168.4.12 respectively. I can ping the bridge from my raspberry, but I cannot ping my laptop which is connected via the wlan0 interface even though it has an IP assigned. I cannot ping my raspberry from my laptop either.
| | -> NIC1 ------> WiFi AP (pi-ap) (192.168.4.0/24)
| | (wlan0 - 192.168.4.1/24)
| PI | ------------
| | -> NIC2 -------> NIC1 | HUE bridge |
--------- (eth0 - 192.168.4.2/24) ------------
(eth0 - 192.168.4.12/24)
This is my /etc/dhcpcd.conf:
interface wlan0
static ip_address=192.168.4.1/24
interface eth0
static ip_address=192.168.4.2/24
net.ipv4.ip_forward is enabled in /etc/sysctl.conf
I have this in my /etc/dnsmasq.conf:
interface=wlan0
dhcp-range=192.168.4.10,192.168.4.20,255.255.255.0,24h
interface=eth0
dhcp-range 192.168.4.3,192.168.4.5,255.255.255.0,24h
And this is my /etc/hostapd/hostapd.conf
interface=wlan0
driver=nl80211
ssid=pi-ap
hw_mode=g
channel=7
wmm_enabled=0
macaddr_acl=0
auth_algs=1
ignore_broadcast_ssid=0
wpa=2
wpa_passphrase=raspberry123
wpa_key_mgmt=WPA-PSK
wpa_pairwise=TKIP
rsn_pariwise=CCMP
I updated my iptables with an ACCEPT ALL policy to ensure no traffic is being blocked:
iptables -F
iptables -X
iptables -t nat -F
iptables -t nat -X
iptables -t mangle -F
iptables -t mangle -X
iptables -P INPUT ACCEPT
iptables -P FORWARD ACCEPT
iptables -P OUTPUT ACCEPT
How can't I ping between the raspberry and the laptop if it is connected to the network and has an IP assigned? Am I missing any configuration?
Edit: I think it might be a routing issue. If I run route -n in my raspberry the result is:
192.168.4.0 0.0.0.0 255.255.255.0 U 202 0 0 eth0
192.168.4.0 0.0.0.0 255.255.255.0 U 303 0 0 wlan0
Do I need to add or modify something to the routing table?
sudo iw dev wlan0 set 4addr onand then addwlan0to the bridge? Is there an error message? – Ingo Apr 30 '18 at 08:37
