In order to connect to a WPA-enterprise network (eduroam) I currently have to do the following (I am using Raspbian GNU/Linux 9 (stretch)):
Modify
/etc/network/interfaces
to include
auto wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
pre-up wpa_supplicant -B -Dwext -i wlan0 -c/etc/wpa_supplicant/wpa_supplicant.conf
post-down killall -q wpa_supplicant
and I add my network information to:
when I restart the PI I need to kill the running wpa_supplicant:
ps -C wpa_supplicant
sudo kill $ProcessID
sudo rm /var/run/wpa_supplicant/wlan0
then I can connect to wifi by running wpa_supplicant manually:
sudo wpa_supplicant -i wlan0 -c /etc/wpa_supplicant/wpa_supplicant.conf
So my question is then: How do I stop the network manager from starting its wpa_supplicant service and instead start the one which gets defined by /etc/wpa_supplicant/wpa_supplicant.conf
thanks in advance
Jesse
EDIT
reading through the link on setting up WIFI it is mentioned:
wpa_supplicant-"$interface".conf in /etc/wpa_supplicant/ e.g. wpa_supplicant-wlan0.conf will only be used by wlan0
so I copied my wpa_supplicant.conf to wpa_supplicant-wlan0.conf and removed my modifications to /etc/network/interfaces and after rebooting am able to automatically connect. This is a much simpler solution.
