First of all I read a lot of thread about problems with connections but all referred to a Wi-Fi LAN adapter. My problem is on the eth0 LAN port.
I have a Raspberry Pi 2 Model B with the latest stable Raspbian installed. I use it as a DHCP server so I configured a static IP. The problem is: after a reboot, the LAN port seems disabled. No ping, ssh or VNC work. But if I connect via real VNC over the cloud I can access the RPi and immediately after connected eth0 starts and i can ping or access ssh.
It seems the LAN port wakes up after an external input.
But after some minutes after disconnect from VNC again the LAN port goes to sleep.
This is my /etc/network/interfaces:
iface eth0 inet static
address 192.168.3.91
netmask 255.255.255.0
broadcast 192.168.3.255
network 192.168.3.0
mtu 1500
gateway 192.168.3.1
And this is my /etc/dhcpcd.conf:
interface eth0
static ip_address=192.168.3.91
static routers=192.168.3.1
static domain_name_servers=208.67.222.222 208.67.220.220
static domain_search=
I tried with
- auto eth0
- inet manual (instead static)
- using a script executed on boot with sudo ifup eth0
but nothing worked...
On boot, the LAN port is not responding to pings.
arp reply
. Connecting from the cloud (what ever this is) your pc get anarp reply
from the pi 2 so the pc knows its mac address and stores it the arp cache. Without refresh the entry will be deleted after 300 sec by default. If you connect through your local network wherearp reply
does not work connection will work for max. 300 sec (without refresh from cloud connection). Mabye ... Is there any firewall? – Ingo Apr 21 '18 at 11:09For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'** Unless you specify what you did no one can tell. Also your
– Milliways Apr 21 '18 at 11:13dhcpcd
settings are wrong.interfaces
ordhcpcd.conf
but still same problem. Connection goes up and down without reason. – Simone Bissi Apr 21 '18 at 14:43
