I am setting up a VPN router on the pi3 and would like to ask two things that I am stuck on.
I would like to disable the onboard WiFi that is assigned to wlan0, as I have two external adapters i'd like to use, one of which is for the wifi. Can I do that somehow without actually disabling the wlan0 interface so I can use it for something else?
My current wifi network is open type of network that you connect to and it redirects you to a website where you enter your username and password and it enables broadband. How do I actually enable this wifi network on wlan1 if it redirects you within the cli?
I have actually disabled the onboard using the config file. Now after plugging in the dongles they are automatically assigned to wlan0 and wlan1. So one dongle took over the onboard NIC's job on wlan0 and I have actually enabled the internet within the GUI and going onto the web. However, now the wlan1 automatically connects to the same network, as there are two Access Points in the corridor (I think). How can I disable the wlan1 to connect to the second access point?
Thanks for you help
