I just installed stretch on my RPi 3 B+ running Raspbian Stretch. During installation it asked for my WiFi network info. However, it wouldn't accept it. I have it now working with a wired internet connection, but how do I now try to configure WiFi again?
Asked
Active
Viewed 563 times
In addition, you might try this:
sudo iwlist wlan0 scan
Verify that your SSID (ESSID) is in the list.
There's a detailed how-to for wifi configuration at the Rpi/documentation website if you want to setup wifi from the command line. And finally, the if you're running "headless" you can now edit the wpa-supplicant
file in /boot
on the uSD card... actually, I'm pretty sure you can do this running "with head" :) also, but it's required for wifi access if you're headless.
Seamus
- 21,900
- 3
- 33
- 70
Assuming that the problem is a mistyped SSID or passphrase, run raspi-config
- Select 2 - Network Options to set the Wifi SSID and passphrase.
- While you at it, select 4 - Localization Options and confirm that your Wifi region is set correctly.
dlu
- 459
- 3
- 19
– jsotola Apr 06 '18 at 19:56
