I have Ubuntu Core installed on a Raspberry Pi 3.
The purpose is to use the Pi as the brains of a robotic system I am building so executing Python code which interacts with the Pis' pins through GPIO is essential.
Executing my python script results in the following error message:
  File "motors.py", line 3, in <module>
    import RPi.GPIO as gpio
ImportError: No module named RPi.GPIO
So I looked for a resource to guide me in installing RPi.GRIO. But when I try I get the following message:
sudo apt-get install python-rpi.gpio python3-rpi.gpio -y
Reading package lists... Done
Building dependency tree
E: Unable to locate package python-rpi.gpio
E: Couldn't find any package by glob 'python-rpi.gpio'
E: Couldn't find any package by regex 'python-rpi.gpio'
E: Unable to locate package python3-rpi.gpio
E: Couldn't find any package by glob 'python3-rpi.gpio'
E: Couldn't find any package by regex 'python3-rpi.gpio'
That should work for Raspbian but it seems to me Ubuntu Core might not have a python GPIO package - I hope I'm wrong.
Can anyone help, please? I desperately need to interface with GPIO or all my hard work is for nought.
UPDATE:
I tried this but received the following error message:
sudo apt-get install python-pip python-dev python3-dev -y
sudo pip install RPI.GPIO
  File "/usr/bin/pip", line 11, in <module>
    sys.exit(main())
  File "/usr/lib/python2.7/dist-packages/pip/__init__.py", line 215, in main
    locale.setlocale(locale.LC_ALL, '')
  File "/usr/lib/python2.7/locale.py", line 581, in setlocale
    return _setlocale(category, locale)
locale.Error: unsupported locale setting
sisko
  • 305
  • why do you need to run Ubuntu? – jsotola Mar 20 '18 at 01:21
    have you seen this? https://askubuntu.com/questions/621134/gpio-on-raspberry-pi – jsotola Mar 20 '18 at 07:35
    @jsotola: I updated my post with feedback. And I'm running ubuntu because it's the only OS that supports ROS - as far as I know – sisko Mar 20 '18 at 08:47
  • @jsotola: Your suggestion worked, with some adjustments. If you want to provide an answer, I will accept it – sisko Mar 20 '18 at 09:50
  • ROS can be installed on Raspbian but it looks quite involved (I should also note that link talks about Raspbian Jessie which is rather out of date now). I'm quite surprised pip is broken on Ubuntu Core, but then Core isn't "normal" Ubuntu - you may want to try Ubuntu MATE which is much closer to "normal" Ubuntu. – Dave Jones Mar 20 '18 at 10:13
this is reprint of an answer by karel at this location https://askubuntu.com/questions/621134/gpio-on-raspberry-pi
In the terminal type:
sudo apt-get update
sudo apt-get upgrade
sudo pip install RPi.GPIO
The raspberry-gpio-python examples are worth reading. In the Inputs example there is this code snippet:
while GPIO.input(channel) == GPIO.LOW:
    time.sleep(0.01)
It waits 10 ms to give CPU a chance to do other things.
jsotola
  • 646
  • youll get this error:
      File "relay_board.py", line 10, in <module>
        GPIO.setup(20, GPIO.OUT, initial=GPIO.LOW)
    RuntimeError: Not running on a RPi!
    Editing your LC_ALL environment variable does not work
    Running with sudo permissions works for me
    – Airfield20 Jan 08 '20 at 17:29
You can just install the GPIO library for Python3 using the command
sudo apt-get install python3-rpi.gpio
It worked for me for Ubuntu 20.04 and 22.04
After that, you can follow the steps for using the GPIO library here sparkfun- raspberry pi gpio
It is because your environment variable LC_ALL is missing or invalid somehow. just run
$ export LC_ALL=C
