When I booted raspbian on raspberry pi, the name of partition is
/dev/mmcblk0
But when I connect sd card via USB reader on Ubuntu 16.04, it shows a different name as
/dev/sdc
These sd cards are same. So what happened here?
And also does this matter when I backup and separate as two partitions with the different name by using
dd and fdisk commend ?
  • What happened is USB card reader having a different name than a native SD/MMC reader in Linux. Why did you expect them to be the same? This is nothing to worry about. – Dmitry Grigoryev Mar 19 '18 at 10:14
You mount your SD Card on different computer. All what you describe is as expected. It depends on how the SD Card is connected to the computer [1]. On your Ubuntu it is connected with an USB card reader. With this it enumerates device names just as they are connected beginning with /dev/sda, e.g. for your mounted hard disk, /dev/sdb for your CD drive and /dev/sdc for your SD Card because it was connected at last. On your raspberry pi it is connected into its slot. For this there is used a special device naming /dev/mmcblk0. For details look at the reference.
references:
[1] https://www.tldp.org/HOWTO/Partition-Mass-Storage-Definitions-Naming-HOWTO/x99.html
  • 42,107
  • 85
  • 197
  • Thank you for your answer. I suffered from creating a new partition. If we didn't name the label of the new partition (not labeled), it would displays UUID. So I created the label of the partition and also I modified /etc/fstab because whenever I boot my raspberry pi, it replace the mount point to UUID automatically. Anyway I solved those problems and thank you so much. – Noki Lee Mar 15 '18 at 07:03
  • Btw. with creating new partitions on SD Card have an attention that you do not run into the problem with PARTUUID on images. – Ingo Mar 15 '18 at 09:18
