I'm looking for a way to have an autonomous Raspberry Pi.
The idea is to have a Raspberry Pi outdoor, with a camera, + possible weather sensor and Wi-Fi mesh (I might looking for too much...)
Any idea of the requirement for make it autonomous (self powered by solar / wind)?
I have no idea of how much power I need for the battery to run it 24h in Ireland (pretty dark and cloudy...)
Peter Mortensen
  • 2,004
Kevin
  • 237
  • related: https://raspberrypi.stackexchange.com/questions/86/how-can-i-run-the-pi-on-solar-power – Fabian Mar 04 '18 at 12:00
  • Keep in mind that sizing the battery should take into account extended darkness/cloudyness/lack of light, making it big enough to last 48h would be a good first measure. – John Keates Mar 04 '18 at 15:33
  • There is a lot of statistics and data for sunshine, ex. https://www.met.ie/climate-ireland/sunshine.asp – MatsK Mar 05 '18 at 09:47
  • See https://raspberrypi.stackexchange.com/questions/5033/how-much-energy-does-the-raspberry-pi-consume-in-a-day – Dmitry Grigoryev Mar 05 '18 at 14:21
It depends on how much current the Raspbery Pi consumes and that depends on:
  • Raspberry Pi version
  • What is running on the Raspberry Pi
  • Any add-on hardware
The theoretical approach is :
Power (watt) = U (voltage) x I (Current)
And for the battery: = Current x Hours = Amp/Hours
This is values from a specific setup, just here for reference. enter image description here
http://raspi.tv/2016/how-much-power-does-raspberry-pi3b-use-how-fast-is-it-compared-to-pi2b
I would recommend to meassure the power on your setup and calculate from that. And I would also recommend to search for "power conservation".
Some other references:
https://www.raspberrypi.org/forums/viewtopic.php?t=6050
https://www.pidramble.com/wiki/benchmarks/power-consumption
MatsK
  • 2,791
