I have bought a Model A Pi, and I successfully configured it with a USB Wifi dongle on Raspbian. I recently prepared an SD card with the latest version of Arch Linux ARM and I am trying to get it set up with WiFi. I was trying to follow a Raspbian WiFi tutorial (thinking it could be the same as Arch Linux ARM) which said that there is a directory /etc/network/ and you could set up WiFi from the interface file, but no directory /etc/network/ exists. I heard about netctl but I have no Idea how to use it! I do have a supported USB WiFi dongle. Could someone please show me how I can setup WiFi on Arch Linux ARM? Thanks!
- 34,687
- 17
- 103
- 109
- 1,270
- 4
- 14
- 17
3Have you read the wiki page? https://wiki.archlinux.org/index.php/Netctl – Alex Chamberlain Jun 16 '13 at 07:04
@AlexChamberlain Yes I have, but I had found it very confusing, thanks though – user151324 Jun 16 '13 at 17:19
The deprecated netcfg used /etc/network.d/ to store profiles. The successor of netcfg is netctl.
In order to setup a wireless network, install netctl using sudo pacman -S netctl. Next, you have to create a network profile. /etc/netctl/examples/ contains some examples. Let's assume you want to setup a WPA2-PSK network. Simply copy over the example file and start editing:
/etc/netctl# install -m640 examples/wireless-wpa wireless-home
/etc/netctl# cat wireless-home
Description='A simple WPA encrypted wireless connection'
Interface=wlan0
Connection=wireless
Security=wpa
IP=dhcp
ESSID='MyNetwork'
# Prepend hexadecimal keys with \"
# If your key starts with ", write it as '""<key>"'
# See also: the section on special quoting rules in netctl.profile(5)
Key='WirelessKey'
# Uncomment this if your ssid is hidden
#Hidden=yes
Edit MyNetwork and WirelessKey as needed. Note the 640 permissions, you do not want to leak your wireless passphrase to the world!
Proceed with testing:
# netctl start wireless-home
If you do not get an error, you should be connected. Let's test this:
$ ping 8.8.8.8
To make this network start on boot:
# netctl enable wireless-home
- 1,501
- 15
- 24
Use
journalctl -afto watch your logs. There may be multiple reasons, like incorrect password or SSID. Perhaps you have to changewlan0to something different due to a udev change, runifconfigto determine the correct name for the wireless interface. If you have more bad luck, your USB dongle is not entirely supported by the driver. – Lekensteyn Jun 18 '13 at 08:15 -
@Lkensteyn Okay, thanks, I have a supported wifi dongle and it worked out of the box with raspbian. I'll try it out! Thanks! – user151324 Jun 18 '13 at 14:41
1Found this to be accurate, however, I ran into the following problems/solutions: "Profile
does not exist or is not readable" - using a dash in the name of the profile causes some escape issues. had to take out the dash; "The interface of network profile – jlsecrest Jun 11 '14 at 11:55is already up - had to take wlan0 down before starting my profile - ip link wlan0 down;netctl start <profile-name> -
(errors above seen after running the command, failing, and then checking
journalctl -xn) – jlsecrest Jun 11 '14 at 12:01 -
If you are working with things like rpi0 without a wired connection, you could do
sudo arch-chroot /tmp/a/root/first. – Qian Chen Jul 22 '20 at 12:41
This didn't work for me at first. After following the above instructions, I had to run
systemctl enable netctl-auto@wlan0
to make it work. I found the answer at the ArchLInux Arm Forum
- 71
Note that for this to work, you must disable all your netctl profiles first, e.g.
# netctl disable home-wifi, and that thewlan0has to match your interface name, not your profile under/etc/netctl/. After that's done, this seems spot-on. – Ionoclast Brigham Aug 11 '14 at 23:52
