-2
I am little bit confused. All my colleagues tell me that I need 2.5 or 3A power source. Indeed, it does not work with with "smaller" source.
However, the general knowledge and this site (and many others) https://www.jeffgeerling.com/blogs/jeff-geerling/raspberry-pi-zero-power tell that the consumption is much lower.
Why and when it needs such a high current from source?
matousc
  • 97
As @joan said in a comment the 2.5 Amp power source is recommended for Pi3 B model (the most common one) for Raspberry Pi Zero and Raspberry Pi Zero W models the recommended power is much lower (1.2 Amp) if you want to know what is the power source you need for your model I recommend to consult this table: https://www.raspberrypi.org/help/faqs/#topPower
Cheesy
  • Thanks and sorry for irrelevant link, but question still stands. If (for example 3B) cannot draw more than 2A, why it crashes with source over 2A (below 2.5A)? – matousc Feb 16 '18 at 11:51
  • @matousc That bears no relation to your actual question. If you have asked the wrong question please clarify what you are asking by editing your question. – joan Feb 16 '18 at 13:03
The Pi3 will run quite happily on a quality 1A supply.
If it does not work you have a PS or cable problem.
See Raspberry Pi Power Limitations
Many Pi users do not understand "current" - provided the voltage is correct it will run - of course this means the PS has to be able to deliver the correct voltage at the current actually required.
