So I have set up my raspberry pi as a wireless access point using HostAPD and Bridge.
I have bridged my wlan0 to eth0. And I can connect to my Access Point successfully. But I also have a webserver on that Pi. And with the access point software I cannot seem to be able to connect to my pi via SSH over ethernet. Like I usually would.
I have scanned my network and my raspberry pi does not show up anymore, so I cant SSH to it or use It as a WebServer
It there any way I can allow this or is this a direct limitation of using the Pi as a WAP Bridge?
Thank you
cobra12
  • 143
Try assigning an IP address to the bridge interface (e.g. br0),
bobstro
  • 3,998
  • 27
adding an IP to br0 solved this problem for me. thanks.
  • raspbian 10.3: /etc/network/interfaces
auto br0
iface br0 inet static
  bridge_ports eth0 wlan0
  address 10.0.0.10
  broadcast 10.0.0.255
  netmask 255.255.255.0
  gateway 10.0.0.1
  • thank you for the advice, the easiest fix I've seen. IP addresses of course have to comply with your routers network its not 10.0... for all – sleepyhead Nov 20 '21 at 10:40
