I am using raspberry pi 3 and edimax Wi-Fi dongle. I have some rules defined inside /etc/udev/rules.d/99-com.rules like what to do when edimax wifi dongle is connected/disconnected
Vendor id I obtained after running lsusb is as below
Bus 001 Device 004: ID 7392:7811 Edimax Technology Co., Ltd EW-7811Un 802.11n Wireless Adapter [Realtek RTL8188CUS]
Accordingly I added the below rules
KERNELS=="[1-9]*-[0-9]*", SUBSYSTEMS=="usb", ACTION=="add", ATTRS{idVendor}=="7392", RUN+="/home/pi/dongleon.sh &"
KERNELS=="[1-9]*-[0-9]*", SUBSYSTEMS=="usb", ACTION=="remove", ATTRS{idVendor}=="7392", RUN+="/home/pi/dongleoff.sh &"
Now I don't want any other USB plugged into raspberry pi ports to work. I want to allow only edimax Wi-Fi dongle and block all other usb devices.
Can some one please let me know how to achieve this.
Pavan
Check out this guide and this answer on Unix SE.
First, add a rule to disable all USB devices by default:
ACTION=="add", SUBSYSTEMS=="usb", RUN+="/bin/sh -c 'for host in /sys/bus/usb/devices/usb*; do echo 0 > $host/authorized_default; done'"
Then, add a rule to enable that particular dongle by vendor ID:
ACTION=="add", ATTR{idVendor}=="7392" RUN+="/bin/sh -c 'echo 1 >/sys$DEVPATH/authorized'"
You should also keep the rules you have if you need to run custom scripts when the dongle is plugged in.
Dmitry Grigoryev
  • 27,928
  • 53
  • 144
