On a freshly imaged stretch lite (it would be the same on a regular stretch or jessie) I've set-up wpa_supplicant.conf with 2 known wifi networks. After boot, the system selects one of the network specified in wpa_supplicant.conf, but how do I select the other one from the command line (without editing wpa_supplicant.conf of course!)?
Asked
Active
Viewed 2,909 times
calocedrus
- 601
- 9
- 12
Why? What are you attempting to achieve? – Milliways Jan 30 '18 at 08:50
Just chose one network over the other one. One of the SSID is my phone hotspot the other is a company's and requires a different password every 24hrs. – calocedrus Jan 31 '18 at 00:04
Related: https://raspberrypi.stackexchange.com/q/58304/63024 – calocedrus Jan 31 '18 at 01:22
See this for more thorough explanations: https://raspberrypi.stackexchange.com/questions/58304/how-to-set-wifi-network-priority – jshep321 Jul 10 '20 at 16:49
It is not AFAIK possible to select by SSID, but you can manually select with something like the following.
wpa_cli select_network 1
It is quite a while since I used this, but networks are identified by position in wpa_supplicant.conf.
If you want to prefer one network setting priority is a better method.
- 31
- 101
- 209
So the index 1 in
wpa_cli select_network 1corresponds to the order of my networks in wpa_supplicant.conf? I'll try this soon. – calocedrus Jan 31 '18 at 00:07 -
Feedbacks on your answer: (1)
wpa_cli select_network xwith x = 0 or 1 returns the sameSelected interface 'p2p-dev-wlan0'OK, and with both WiFi networks correctly broadcasting, my RPi still connects to only one of them, so this doesn't allow to switch between networks. (2) The position inwpa_supplicant.confdoes not select the priority (setting my own hotspot in 2nd position inwpa_supplicant.confwill chose it even with the other WiFi turned on and set in 1st position). – calocedrus Jan 31 '18 at 01:14 -
And (3): I suppose that by setting priority you mean adding
priority = xwith x = 1, 2, ... insidenetwork {...}inwpa_supplicant.conf? – calocedrus Jan 31 '18 at 01:16 -
As I said it has been some time since I used it (while testing with a number of AP). According to
wpa_cli list_networksit works, I just switched from1 PiNET any [CURRENT]to1 PiNET any [DISABLED]butiwconfigshowswlan0 IEEE 802.11 ESSID:"PiNET"Maybe the wireless hook indhcpcdgets in the way. – Milliways Jan 31 '18 at 01:37 -
Here's my experiment: (a) after reboot I'm connected to wifi_hotspot. (b)
wpa_cli list_networksshows the 2 lines0 other_wifi anyand1 myhostpot any(c)wpa_cli select_network 1(d)wpa_cli list_networksthen shows0 other_wifi any [DISABLED]and1 myhostpot any [CURRENT](e)wpa_cli select_network 0(f)wpa_cli list_networksshows0 other_wifi any [CURRENT]1 myhostpot any [DISABLED]. But I still see me as a connected user on my hotspot and still have the same IP address (ifconfig), and can do apt-get install (I didn't set the other wifi password so not connectd)! – calocedrus Jan 31 '18 at 02:58
