I have read a number of posts on this topic, so I went into my router's network map to see what I could learn. I discovered that my RPi, which is connected by ethernet cable, has two different IP addresses. Could this cause it not to show up as a network share?
One of the IP addresses is a fixed address that I set in order to use the Pi as a Plex server. The Plex server function is working fine. Can I delete the other IP address, without messing things up? How do I do that? I'm obviously over my head when it comes to network administration. Thanks for any light you can shed on this problem.
