━━━ Installation using a Raspberry Pi ━━━
This installation uses a Raspberry Pi for setup. If you want to use another computer then look at the other answer here: Setup using a Linux computer with intel processor.
You need two SD Cards, one to boot the RasPi and one attached with your SD Card reader on an USB port of the RasPi. I will try to present two installation paths because they are similar and have many common setups. First I will install Raspbian on two primary partitions as it is done on the default image Raspbian Buster. This is less error prone for newbies or to get quick a running system. On the other path I will use logical volumes because I love to use its nice features for easy backup, restore from snapshots, desaster recovery and others. I labled the setups with COMMON, PRIMPART (primary partitions) and LVM. If you want to use primary partitions just follow only parts labled with COMMON and PRIMPART, ignore parts with LVM. Installing logical volumes only use COMMON and LVM.
I will partition and format a virgin SD Card so I'm able to configure it to just what I like. First I prepare the master boot record (MBR), then partition the SD Card and format it. I will do it on the Raspberry Pi so we do not have problems running software for the ARM processor to be used for installation and we can chroot into the new installation and prepare needed things. it is recommended to use an up to date Raspbian version to start the RasPi for installation because we copy some configuration files. For reference I use Raspbian Buster Lite udated with sudo apt update && sudo apt full-upgrade && sudo reboot. I assume you have the internet connection already running.
COMMON:
Boot the RasPi and after login create a default msdos partition table on the empty SD Card. I assume it is attached to /dev/sda:
rpi ~$ sudo -Es
rpi ~# parted /dev/sda mktable msdos
Now we have made a master boot record (MBR), the very first sector with 512 bytes. It also contains a very small boot sequence at the beginning. You can check it with:
rpi ~# hd -v -n512 /dev/sda
Partition the SD Card with sizes what you like. I will use a 16 GB card:
rpi ~# parted /dev/sda mkpart primary fat32 8192s 132MB
rpi ~# parted /dev/sda mkpart primary 132MB 100%
The boot sequence in the MBR is not used by a Raspberry Pi so we will delete it with:
rpi ~# dd if=/dev/zero of=/dev/sda bs=1 count=440 conv=notrunc
This is not really required but I do it to be on the save side because the MBR from the original Raspbian image is also nullified on this sequence. Then we format the first partition with fat32 and make a mount point.
rpi ~# mkfs.vfat -vF 32 -n BOOT /dev/sda1
rpi ~# mkdir /mnt/p2
PRIMPART:
Format the second partition with ext4 and mount it:
rpi ~# mkfs.ext4 -vL rootfs /dev/sda2
rpi ~# mount /dev/sda2 /mnt/p2
LVM:
Setup logical volumes in the second partition, format it with ext4 and mount it:
rpi ~# parted /dev/sda set 2 lvm on
rpi ~# pvcreate /dev/sda2 # define physical volume
rpi ~# vgcreate rpi_vg /dev/sda2 # create volume group using physical volume
rpi ~# lvcreate rpi_vg --name root_lv --size 8G # create logical volume in volume group
# format the logical volume and mount it
rpi ~# mkfs.ext4 -vL rootfs /dev/mapper/rpi_vg-root_lv
rpi ~# mount /dev/mapper/rpi_vg-root_lv /mnt/p2
COMMON:
Mount the boot partition:
rpi ~# mkdir /mnt/p2/boot
rpi ~# mount /dev/sda1 /mnt/p2/boot/
We install the debootstrap installation program and execute it:
rpi ~# apt install debootstrap
rpi ~# /usr/sbin/debootstrap --arch armhf buster /mnt/p2 http://raspbian.raspberrypi.org/raspbian
Now we have a tiny but complete Debian/Raspbian operating system on the new SD Card. We have to do some essential setups. Copy the default repository sources list files:
rpi ~# cp /etc/apt/sources.list /mnt/p2/etc/apt/
rpi ~# cp /etc/apt/sources.list.d/raspi.list /mnt/p2/etc/apt/sources.list.d/
PRIMPART:
First set the kernel boot parameter with boot/cmdline.txt:
rpi ~# echo 'console=tty1 root=/dev/mmcblk0p2 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait' > /mnt/p2/boot/cmdline.txt
You can use console=serial0,115200 instead of console=tty1 if you are using the serial debug console like me. If you don't like Predictable Network Interface Names you can append net.ifnames=0 to cmdline.txt. To make the new SD Card bootable we have to set /etc/fstab:
rpi ~# cat > /mnt/p2/etc/fstab <<EOF
/dev/mmcblk0p1 /boot vfat defaults 0 2
/dev/mmcblk0p2 / ext4 defaults,noatime 0 1
EOF
LVM:
rpi ~# echo 'console=tty1 root=/dev/mapper/rpi_vg-root_lv rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait' > /mnt/p2/boot/cmdline.txt
/dev/mapper/rpi_vg-root_lv / ext4 defaults,noatime 0 1
EOF
COMMON:
Now we chroot into the new tiny installation and install the kernel and firmware:
rpi -# mount --bind /dev/pts /mnt/p2/dev/pts
rpi ~# LANG=C.UTF-8 chroot /mnt/p2 /bin/bash
root@raspberrypi:/# export TERM=linux
apt claims a signing key so we have to get it first:
root@raspberrypi:/# apt-key adv --keyserver hkp://keyserver.ubuntu.com:80 --recv-keys 82B129927FA3303E
The only user on the new installation is root but its password isn't set, so we will not be able to log in after booting the new SD Card. So first set the root password:
root@raspberrypi:/# passwd root
Now we install the kernel and firmware:
root@raspberrypi:/# apt install dialog
root@raspberrypi:/# apt update
root@raspberrypi:/# apt full-upgrade
root@raspberrypi:/# echo raspi4 > /etc/hostname # or what you want to name your RasPi
root@raspberrypi:/# apt install raspberrypi-bootloader
root@raspberrypi:/# apt install libraspberrypi-bin
root@raspberrypi:/# apt install raspberrypi-archive-keyring raspberrypi-sys-mods
root@raspberrypi:/# apt install sudo
# WiFi driver
root@raspberrypi:/# apt install --no-install-recommends firmware-brcm80211 wireless-regdb crda
Only if you want to use the serial debug console, like me, then enable it:
root@raspberrypy:/# echo 'enable_uart=1' >> /boot/config.txt
PRIMPART:
Exit chroot:
root@raspberrypi:/# exit
rpi ~#
LVM:
For the lvm we need to load the driver on early stage boot to be able to access the root volume. So we have to use an init ramdisk and install lvm driver:
root@raspberrypi:/# apt install initramfs-tools
root@raspberrypi:/# apt install lvm2
# I only want to load listed modules
root@raspberrypi:/# sed -i 's/^MODULES=most/MODULES=list/' /etc/initramfs-tools/initramfs.conf
In /boot/config.txt define to load the ramdisk depending on the Raspberry Pi version. First look what modules have to be loaded, for example:
root@Raspberrypi:/# ls /lib/modules
4.19.97+ 4.19.97-v7+ 4.19.97-v7l+ 4.19.97-v8+
Then at the top of /boot/config.txt insert these lines:
[pi3]
initramfs initrd.img-4.19.97-v7+ followkernel
[pi4]
initramfs initrd.img-4.19.97-v7l+ followkernel
# arm_64bit=1
# initramfs initrd.img-4.19.97-v8+ followkernel
[all]
Finally create the needed init ramdisks and exit chroot. You can ignore warnings:
root@Raspberrypi:/# mkinitramfs -o /boot/initrd.img-4.19.97-v7+ 4.19.97-v7+
root@Raspberrypi:/# mkinitramfs -o /boot/initrd.img-4.19.97-v7l+ 4.19.97-v7l+
rpi ~#
Don't forget to update the ramdisk version and recreate it if you update kernel or firmware, otherwise it may be possible that you cannot boot anymore. But then you can mount the SD Card to your RasPi like this, chroot into it and recreate the ramdisk.
COMMON:
Clean up and poweroff:
rpi ~#
rpi ~# umount /mnt/p2/boot
rpi ~# umount /mnt/p2/dev/pts
rpi ~# rmdir /mnt/p2
rpi ~# systemctl poweroff
Now change the SD Card and boot the new installation. Login with root.
We have a clean tiny but working Raspbian with usable apt package manager. It consumes just 356 MB of diskspace for the root partition. This is a good starting point to build custom environments or to learn how it works step by step. Maybe you will first make an account for a normal user and configure network connection, so you can use apt to install software packages.
references:
(1) How to make an image file from scratch
(2) Easy backups and snapshots of a running system with LVM
