My Pi3 running Jessie loses connectivity after unplugging and plugging back the ethernet cable. It's literally driving me crazy. Hope you could shed some light here.
Wifi is disabled in /boot/config and raspi-blacklist.
/etc/network/interfaces is as follows:
auto lo
iface lo inet loopback
auto eth0
allow-hotplug eth0
iface eth0 inet manual
#allow-hotplug wlan0
#iface wlan0 inet dhcp
#    wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
#allow-hotplug wlan1
#iface wlan1 inet manual
Thank you
I had a similar problem that the network would not work after restarting the switch attached.
The problem was solved by
ifconfig eth0 down && ifconfig eth0 up
As my machine is headless, I set up a script to bother with keeping the connection alive.
Here is a pseudo code example
if (ping 192.168.0.1 doesn't work) then ifconfig eth0 down && ifconfig eth0 up && sleep 120 #to reduce the load implied by the script and give the system a chance to get its DHCP set up.
end if
mldevw
