I bought a small gigabit ethernet USB adapter, which works fine OOTB in a Raspberry Pi 3, but only at 100mbits/s. How can I make it run at full speed?
ethtool:
# ethtool eth1
Settings for eth1:
Supported ports: [ TP MII ]
Supported link modes: 10baseT/Half 10baseT/Full
100baseT/Half 100baseT/Full
1000baseT/Half 1000baseT/Full
Supported pause frame use: No
Supports auto-negotiation: Yes
Advertised link modes: 10baseT/Half 10baseT/Full
Advertised pause frame use: Symmetric Receive-only
Advertised auto-negotiation: Yes
Link partner advertised link modes: 10baseT/Half 10baseT/Full
Link partner advertised pause frame use: Symmetric
Link partner advertised auto-negotiation: Yes
Speed: 100Mb/s
Duplex: Full
Port: MII
PHYAD: 32
Transceiver: internal
Auto-negotiation: on
Supports Wake-on: pumbg
Wake-on: g
Current message level: 0x00007fff (32767)
drv probe link timer ifdown ifup rx_err tx_err tx_queued intr tx_done rx_status pktdata hw wol
Link detected: yes
lshw:
*-network:2
description: Ethernet interface
physical id: 4
logical name: eth1
serial:
capacity: 1Gbit/s
capabilities: ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
configuration: autonegotiation=on broadcast=yes driver=r8152 driverversion=v1.08.8 duplex=full ip=192.168.1.5 link=yes multicast=yes port=MII speed=100Mbit/s
lsmod
Module Size Used by
rpcsec_gss_krb5 23752 0
brcmfmac 222874 0
brcmutil 9092 1 brcmfmac
cfg80211 543027 1 brcmfmac
cdc_ether 6354 0
rfkill 20851 1 cfg80211
r8152 37460 0
bcm2835_gpiomem 3940 0
uio_pdrv_genirq 3923 0
uio 10204 1 uio_pdrv_genirq
fixed 3285 0
snd_bcm2835 24427 0
snd_pcm 98501 1 snd_bcm2835
snd_timer 23968 1 snd_pcm
snd 70032 3 snd_timer,snd_bcm2835,snd_pcm
joydev 9988 0
uinput 9125 0
ipv6 408971 32
First think I noticed is that 1000 is indeed supported, but not advertised. Maybe because the fallback from USB 3 to USB 2 falls back to 100mbits/s as well?
I tried
# ethtool -s eth1 speed 1000 duplex full
But no luck.
The adapter brand is "rankie" (easy to find at amazon).
Also, the adapter is connected to a gigabit switch. My NAS is connected to that switch and is running at 1000mbits/s without issues, so I doubt that is the issue.
Finally, the Ethernet adapter is the only USB device connected to the PI, so even if I don't expect a full 1000mbps, I was expecting to get somewhere to the USB2.0 speed
ethtool. Interestingly, even without configuring the speed, using USB3 adapters increased RPi throughput from ~94 Mbps to ~113 Mbps. I've read of people getting close to 300 Mbps using properly configured USB3 adapters. The USB2 bus supports far higher throughput than 100Mbps, though you won't get 1Gbps. – bobstro Jan 14 '18 at 17:46lshw's output? – Ghanima Jan 14 '18 at 18:29
