I seem to be having a strange problem with my Raspberry Pi - I can ssh to the Pi, but the Pi cannot ping the computer I am ssh'ing from (Windows firewall allows ICMP packets). I have the Pi configured to have a static IP on eth0, and it is connected directly to my PC with an ethernet cable. The PC has a static ip of 192.168.0.2, a netmask of 255.255.255.0, and a gateway of 192.168.0.5.
The contents of /etc/network/interfaces:
auto lo
iface lo inet loopback
auto eth0
iface eth0 inet manual
auto wlan0
allow-hotplug wlan0
iface wlan0 inet manual
# post-up route add default gw 10.110.0.11; echo "1" > /proc/sys/net/ipv4/ip_forward ; iptables -t nat -A POSTROUTING -o wlan0 -j MASQUERADE
And at the bottom of /etc/dhcpcd.conf:
interface eth0
static ip_address=192.168.0.5/24
static routers=192.168.0.2
static domain_name_servers=8.8.8.8 8.8.4.4
Output of ifconfig:
eth0 Link encap:Ethernet HWaddr b8:27:eb:8b:a0:66
inet addr:192.168.0.5 Bcast:192.168.0.255 Mask:255.255.255.0
RX packets:534 errors:0 dropped:0 overruns:0 frame:0
TX packets:392 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:37966 (37.0 KiB) TX bytes:44764 (43.7 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:40 errors:0 dropped:0 overruns:0 frame:0
TX packets:40 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:0
RX bytes:3232 (3.1 KiB) TX bytes:3232 (3.1 KiB)
wlan0 Link encap:Ethernet HWaddr 00:0b:81:89:08:c9
inet addr:10.110.191.221 Bcast:10.110.255.255 Mask:255.255.0.0
RX packets:20 errors:0 dropped:10 overruns:0 frame:0
RX bytes:8486 (8.2 KiB) TX bytes:5814 (5.6 KiB)
The end goal is to use iptables with MASQUERADE to allow the Windows PC to access the internet using the Pi's connection on wlan0, which also hasn't been working - I figured this should be resolved first and is indicative of a deeper problem, but I am new to networking so any advice is deeply appreciated!
sshworks -- so the Windows firewall is a likely culprit. I assume the PC can ping the RPi. Try another device, or (not recommended) modify the firewall settings. – bobstro Jan 12 '18 at 11:31/etc/dhdpcd.conf(192.168.0.2) that might be over-writing DHCP's. – bobstro Jan 12 '18 at 17:39
