I have sample app that wait on signal from IR sensor that is connected to GPIO15 and 14:
ser = serial.Serial(port="/dev/ttyAMA0",baudrate=115200, timeout=1)
io.add_event_detect(15,io.RISING, callback=inputLow, bouncetime=200)
def inputLow(channel):
  print('signal test')
And now I want to run screen: screen /dev/ttyAMA0 115200
  • 1) I can only run screen because when I run above application I get error device ttyAMA0 is busy
  • 2) when I run only gnu screen in terminal I see only black screen, when I send signal to IR sensor on the terminal nothing happens, screen is black
How can I read data from ttyAMA0?
user79083
There is ABSOLUTELY NO REASON to use /dev/ttyAMA0 in a moderately up-to-date OS. This is connected to Bluetooth (by default) on Pi3 and PiZeroW.
In ALL models use /dev/serial0 which is the default serial port (if enabled), even if ports are swapped.
See How-do-i-make-serial-work-on-the-raspberry-pi3
  • my OS is Jessy, so I should use ttyS0 or /dev/serial0? – Robert Jan 09 '18 at 10:45
  • @Robert I don't know this Jessy but the earliest implementations of Raspbian supporting the Pi3 were half baked and poorly documented (which was the reason for my linked post), You can check if /dev/serial0 exists. – Milliways Jan 09 '18 at 10:52
  • ok, ls -l /dev and I see: ttyS0 and ttyAMA0 and serial0->ttyS0, serial1->ttyAMA0 – Robert Jan 09 '18 at 11:05
