HW: Raspberry Pi 3, 16 gig hard drive
Relevant Output:
Starting dhcpcd on all interfaces...
Starting LSB: Autogenerate and use a swap file
Starting LSB: Switch to ondemand cpu governor(unless shift key is pressed)..
reset
Description
If I don't press shift on time my Raspberry Pi constantly resets itself. I used the Raspbian configured openhabian ISO image but my understanding is that this issue is part of Raspbian boot. SSH connection is not possible.
Otherwise image works fine.
Aurora0001
  • 6,308
  • 38
Thomas
  • 151
    We are experiencing the same issue--all of a sudden--with a CM3 module. I don't believe we are on the latest updated version, but definitely Stretch. – Beez Jul 25 '19 at 18:55
My raspberry pi has also suddenly starting going into a restart loop due to this.
I'm not sure why switching to the ondemand cpu governor causes a problem, but I've disabled it for now following instructions in this post: How to change the default governor?
You can do this by disabling the raspi-config service which, for me, didn't do anything other than switch to the ondemand cpu governor. Here's how:
sudo systemctl disable raspi-config
MetaFight
  • 103
  • for reference, the raspi-config mentioned above is not the cli tool used to change config - see https://raspberrypi.stackexchange.com/questions/9034/how-to-change-the-default-governor#answer-9048 – autopoietic Oct 08 '22 at 13:45
