I have bought a Pi and am a little clueless what to do in order to start working on it. I bought a starter kit with a sd-card (NOOBS Software on it). Shouldn't it be possible, to put the micro-sd in the Pi, plug in the power-cable and access the Pi via ssh (headless)?
I read, that ssh must be actived in some cases before. But when I plug in the sd-card in my PC I see something like this:
I created an empty file "ssh" (no file extensions) to activate ssh, as can be seen.
However, whenever I type ssh pi@192.168.x.x, on my Ubuntu Terminal on the Home PC, I get Permission denied, please try again. The password I type is raspberry.
Shouldn't everything be set correctly already?
The starter kit is from: https://www.amazon.de/Raspberry-Pi-3-Wert-Starter-Kit/dp/B01M3VQBK1/ref=sr_1_sc_2?ie=UTF8&qid=1514482690&sr=8-2-spell
I think, I have to change the SD-card somehow.. But I am not sure how..
My home PC has Ubuntu 16.04.
Thanks everyone!
EDIT:
Hello again!
Thank you all for your help. I briefly want to share, what I have done so far.
I have installed Raspbian as OS on the sd-card now. It worked.
Then I have added an empty ssh file (no file extension) in order to enable ssh service on the Pi.
Then I created a wpa_supplicant.conf file, which contains my wifi information. It lookes like this:
update_config=1
country=AU
network={
ssid="Your WiFi SSID"
psk="Your WiFi password"
key_mgmt=WPA-PSK
Both, ssh file and wpa_supplicant.conf file are in the boot partition of the sd-card now.
However, ssh connection is still not possible... I still get the permission denied message.
I made some changes in the config.txt and the cmdline.txt file as suggested in this tutorial: https://www.mickmake.com/archives/2777. But it still doesn't work.
I also set a rule in the Ubuntu firewall to allow ssh: sudo ufw allow 22/tcp. That didn't help either.
Another thing, that confuses me is, that the ssh file and the wpa_supplicant.conf seem to have dissapeared after I take the sd-card out of my laptop.
I also tried to check the default password on /etc/passwd, however, I can't find it in there:
root:x:0:0:root:/root:/bin/bash
daemon:x:1:1:daemon:/usr/sbin:/usr/sbin/nologin
bin:x:2:2:bin:/bin:/usr/sbin/nologin
sys:x:3:3:sys:/dev:/usr/sbin/nologin
sync:x:4:65534:sync:/bin:/bin/sync
games:x:5:60:games:/usr/games:/usr/sbin/nologin
man:x:6:12:man:/var/cache/man:/usr/sbin/nologin
lp:x:7:7:lp:/var/spool/lpd:/usr/sbin/nologin
mail:x:8:8:mail:/var/mail:/usr/sbin/nologin
news:x:9:9:news:/var/spool/news:/usr/sbin/nologin
uucp:x:10:10:uucp:/var/spool/uucp:/usr/sbin/nologin
proxy:x:13:13:proxy:/bin:/usr/sbin/nologin
www-data:x:33:33:www-data:/var/www:/usr/sbin/nologin
backup:x:34:34:backup:/var/backups:/usr/sbin/nologin
list:x:38:38:Mailing List Manager:/var/list:/usr/sbin/nologin
irc:x:39:39:ircd:/var/run/ircd:/usr/sbin/nologin
gnats:x:41:41:Gnats Bug-Reporting System (admin):/var/lib/gnats:/usr/sbin/nologin
nobody:x:65534:65534:nobody:/nonexistent:/usr/sbin/nologin
systemd-timesync:x:100:103:systemd Time Synchronization,,,:/run/systemd:/bin/false
systemd-network:x:101:104:systemd Network Management,,,:/run/systemd/netif:/bin/false
systemd-resolve:x:102:105:systemd Resolver,,,:/run/systemd/resolve:/bin/false
systemd-bus-proxy:x:103:106:systemd Bus Proxy,,,:/run/systemd:/bin/false
pi:x:1000:1000:,,,:/home/pi:/bin/bash
messagebus:x:104:109::/var/run/dbus:/bin/false
avahi:x:105:110:Avahi mDNS daemon,,,:/var/run/avahi-daemon:/bin/false
ntp:x:106:111::/home/ntp:/bin/false
sshd:x:107:65534::/var/run/sshd:/usr/sbin/nologin
statd:x:108:65534::/var/lib/nfs:/bin/false
lightdm:x:109:114:Light Display Manager:/var/lib/lightdm:/bin/false
pulse:x:110:116:PulseAudio daemon,,,:/var/run/pulse:/bin/false
rtkit:x:111:118:RealtimeKit,,,:/proc:/bin/false
I currently have no ideas, what the problem could be.
