I use a Raspberry Pi Zero W with Raspbian Stretch Lite 2017.11.29. I set up a SSH connection from my laptop to the Pi via USB to configure it.
Now I just do ssh pi@raspberrypi.local on my Ubuntu 17.10 laptop to connect to the Pi. Everything works fine!
Since I want a wireless adapter with a static IP address I added the following to the file /etc/network/interfaces
auto wlan0
iface wlan0 inet static
    address 192.168.255.1
    netmask 255.255.255.0
    wireless-mode Master
    wireless-power off
After doing that I can no longer access my Pi via SSH. My computer also does not find my Pi anymore if I connect it via USB. What can I do to make it work again?
Help of any kind would be highly appreciated.
Gilfoyle
  • 111
  • What to say? Perhaps revert your changes? – joan Dec 05 '17 at 15:50
  • @joan I wanted to do that. But when I opened the file again my changes where gone. So I do not know how I can revert the changes. The file looked like before my changes. – Gilfoyle Dec 05 '17 at 15:58
  • It sounds like you have more than one Pi connected and are using the wrong one, or you are using something like NOOBS, in any case you need to find the file you actually edited and revert the change. – joan Dec 05 '17 at 16:01
  • @joan I am sure that I changed the file /etc/network/interfaces doing sudo vim /etc/network/interfaces. I have only one Pi and I am not using NOOBS. – Gilfoyle Dec 05 '17 at 16:06
You obviously didn't read the contents of the interfaces file, before modifying it.
# For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf
See How to set up networking/WiFi which contains default files for Jessie and Stretch, although in Stretch the interfaces file does nothing and can be deleted.
It is unclear from your question whether you are trying to setup the WiFi as an Access Point, or to access a network. If the latter your settings are wrong/incomplete; if the former additional software is required.
The following describes How to set up Static IP Address
