I have several Pi Zero W all with the latest Rasbian, running headless. After a few hours I lose the ability to contact them via WiFi or SSH, they are however still running as logs show. Basically I have to reboot them at the power plug. I have swapped SD cards around and power adaptors - I'm sure it's a software setting
I have edited /etc/network/interfaces to include the line wireless-power off and iwconfig | grep "Power Management" shows “Power Management:off” but this has no effect
If its any help I am running them on static IP sudo nano /etc/dhcpcd.conf
interface wlan0
static ip_address=192.168.0.xxx/24 static routers=192.168.0.1 static domain_name_servers=192.168.0.1
Any help gratefully received. Thanks
Rubberstamp - Thanks for the help: with journalctl I get No journal files were found. I can see results in cat /var/log/auth.log (but i have no idea what to look for) and systemctl status dhcpcd (the unit has not shut off reads
dhcpcd.service - dhcpcd on all interfaces Loaded: loaded (/lib/systemd/system/dhcpcd.service; enabled) Active: active (running) since Sun 2017-11-26 18:57:12 GMT; 1h 38min ago Process: 371 ExecStart=/sbin/dhcpcd -q -b (code=exited, status=0/SUCCESS) Main PID: 382 (dhcpcd) CGroup: /system.slice/dhcpcd.service └─382 /sbin/dhcpcd -q -b**.
I'm afraid this is all a bit above my pay grade, so thanks for bearing with me
journalctl -u ssh --since YYYY-MM-DDandjournalctl -u dhcpcd --since YYYY-MM-DD– RubberStamp Nov 25 '17 at 15:23
