I had my Raspberry Pi configured to work with a USB microphone (C-Media microphone USB). I had made the following changes
For /lib/modprobe.d/aliases I update the following lines
options snd-usb-audio index=0
options snd_bcm2835 index=1
My asoundrc file has the following
pcm.!default {
type hw
card 0
ctl.!default {
type hw
card 0
My microphone shows up as a USB device when I run lsusb but doesn't show up when I try a arecord -l
I have attached a copy of the dmesg log which shows an error. Any suggestions on fixing this issue are welcome.
][1]][1]in your asoundrc is a typo, right? Because if I include that in/etc/asound.conf, arecord naturally says parse error. I don't have your particular mic, but runningsudo modprobe snd_bcm2835 index=1results in unknown parameter 'index' so perhaps what you want to try instead is:sudo modprobe -r snd_bcm2835; sudo modprobe snd-usb-audio index=0. (Once this is better troubleshooted/easily reproducible at runtime, then we can loop back and try to get it consistent at boot time e.g. /lib/modprobe.d) – jdonald Nov 20 '17 at 06:20sudo modprobe -r snd_bcm2835;sudo modprobe snd-usb-audio index=0Do you have any suggestions on how I can force this error on bootup?
– user2808264 Nov 20 '17 at 09:45lsusbin your question, ideally, in text .... images suck, because they cannot be indexed (for search) and our blind friends cannot help you. – thecarpy Nov 20 '17 at 12:38sudo rm /lib/modprobe.d/aliases) and try to reproduce the error several times at runtime, even try reordering the load of snd_bcm2835. Re-test by unloading each module:sudo modprobe -r snd-usb-audio; sudo modprobe -r snd_bcm2835and then loading again (-rmeans remove, while modprobe normally loads a module if not loaded already). In either situation you can runlsmodto see if other snd modules are loaded and potentially conflicting (and check dmesg) then provide more info. – jdonald Nov 20 '17 at 15:48cat /proc/asound/cards? – MrChips Nov 23 '17 at 04:29
