I do not know why, but when I unplug my ethernet cable, I have no more wifi connection. I use /etc/network/interfaces for configure my static IP
auto lo
iface lo inet loopback
allow-hotplug eth0
iface eth0 inet static
address 192.168.XXX.XX0
netmask 255.255.255.0
gateway 192.168.XXX.XXX
allow-hotplug wlan0
iface wlan0 inet static
address 192.168.XXX.XX1
And my wpa_supllicant.conf is correct
Does anyone know why? Thanks
tlhIngan
  • 3,372
Brian
    What OS/release? What evidence - you have posted no stats. There is no point in being coy about a private IP. Probably 80% of users are using the same. Why did you ignore the warning "# Please note that this file is written to be used with dhcpcd
    For static IP, consult /etc/dhcpcd.conf and 'man dhcpcd.conf'"? What else have you changed?
    – Milliways Nov 09 '17 at 23:52
  • Hi Milliways, i'm very sorry, i'm very noob :-( I think I found by configuring my dhcpcd.conf as follows eth0 interface static ip_address = 192.168.104.20 / 24 static routers = 192.168.104.9 static domain_name_servers = 192.168.104.9 8.8.8.8
    wlan0 interface static ip_address = 192.168.104.21 / 24 static routers = 192.168.104.9 static domain_name_servers = 192.168.104.253 8.8.8.8
    – Brian Nov 10 '17 at 16:36
In case it helps, I have this in my /etc/network/interfaces file:
auto wlan0
iface wlan0 inet dhcp
I'm wondering if adding auto wlan0 might help here.
Will
  • 200
  • Don't use the dhcp bit as you are using static/manual IP address assignment whereas I use dhcp. I just wanted to paste working code, that was all. – Will Nov 12 '17 at 16:16
