I received my Raspberry Pi 3 Model B a few days ago, I copied Raspbian Stretch img with dd to 64 GB Samsung EVO card.
I am using a HDMI to VGA adapter on a 1920x1080 Samsung monitor.
Also, I have enabled G1 GL Full KMS via raspi-config
I have also increased GPU memory from 64 MB to 256 MB.
I have enabled following in Chrome flags:
Override software rendering list
GPU rasterization
Zero-copy rasterizer
I run Chromium with:
chromium-browser --enable-native-gpu-memory-buffers --enable-features="CheckerImaging"
For first day use I didn't have any problems, I had smooth 1080p youtube playback and browsing scrolling was fine. Today I started Chromium and I noticed lag while scrolling.
I have tried rebooting several times and re-applying configuration like GPU memory, GL...
I even tried reinstalling mesa drivers, running rpi-update
I think dmesg clearly shows the problem but I can't understand it:
[ 200.278732] ------------[ cut here ]------------
[ 200.278791] WARNING: CPU: 0 PID: 483 at drivers/gpu/drm/vc4/vc4_plane.c:756 vc4_plane_async_set_fb+0xa4/0xa8 [vc4]
[ 200.278794] Modules linked in: fuse rfcomm bnep hci_uart btbcm bluetooth panel_raspberrypi_touchscreen joydev evdev vc4 drm_kms_helper brcmfmac drm brcmutil snd_soc_core snd_compress snd_pcm_dmaengine syscopyarea cfg80211 sysfillrect sysimgblt i2c_gpio snd_bcm2835 fb_sys_fops i2c_algo_bit rfkill snd_pcm snd_timer snd i2c_bcm2835 bcm2835_gpiomem uio_pdrv_genirq uio fixed sg i2c_dev ip_tables x_tables ipv6
[ 200.278890] CPU: 0 PID: 483 Comm: Xorg Not tainted 4.9.59-v7+ #1047
[ 200.278893] Hardware name: BCM2835
[ 200.278916] [<8010fb3c>] (unwind_backtrace) from [<8010c058>] (show_stack+0x20/0x24)
[ 200.278926] [<8010c058>] (show_stack) from [<80456764>] (dump_stack+0xd4/0x118)
[ 200.278938] [<80456764>] (dump_stack) from [<8011d348>] (__warn+0xf8/0x110)
[ 200.278947] [<8011d348>] (__warn) from [<8011d430>] (warn_slowpath_null+0x30/0x38)
[ 200.278983] [<8011d430>] (warn_slowpath_null) from [<7f4aeb5c>] (vc4_plane_async_set_fb+0xa4/0xa8 [vc4])
[ 200.279057] [<7f4aeb5c>] (vc4_plane_async_set_fb [vc4]) from [<7f4aec2c>] (vc4_update_plane+0xcc/0x154 [vc4])
[ 200.279260] [<7f4aec2c>] (vc4_update_plane [vc4]) from [<7f34ef4c>] (__setplane_internal+0x190/0x238 [drm])
[ 200.279530] [<7f34ef4c>] (__setplane_internal [drm]) from [<7f34f114>] (drm_mode_cursor_universal+0x120/0x1bc [drm])
[ 200.279765] [<7f34f114>] (drm_mode_cursor_universal [drm]) from [<7f34f23c>] (drm_mode_cursor_common+0x8c/0x194 [drm])
[ 200.279994] [<7f34f23c>] (drm_mode_cursor_common [drm]) from [<7f34f8ec>] (drm_mode_cursor2_ioctl+0x18/0x1c [drm])
[ 200.280228] [<7f34f8ec>] (drm_mode_cursor2_ioctl [drm]) from [<7f332c60>] (drm_ioctl+0x20c/0x428 [drm])
[ 200.280373] [<7f332c60>] (drm_ioctl [drm]) from [<80283b74>] (do_vfs_ioctl+0xac/0x820)
[ 200.280385] [<80283b74>] (do_vfs_ioctl) from [<8028432c>] (SyS_ioctl+0x44/0x6c)
[ 200.280399] [<8028432c>] (SyS_ioctl) from [<801080c0>] (ret_fast_syscall+0x0/0x1c)
[ 200.280405] ---[ end trace 81688151713e1c56 ]---
This is my config.txt
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
#disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
hdmi_group=2
hdmi_mode=82
# Tells the Pi to ignore everything that the monitor is telling it about the resolution it can run at
hdmi_ignore_edid=0xa5000080
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
config_hdmi_boost=7
# uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
#dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
gpu_mem=256
dtoverlay=vc4-kms-v3d
#dtoverlay=vc4-fkms-v3d
Also here is my chrome://gpu
uname -a
Linux raspberrypi 4.9.59-v7+ #1047 SMP Sun Oct 29 12:19:23 GMT 2017 armv7l GNU/Linux
Still confused
– Luka Nov 09 '17 at 16:33sudo apt update && sudo apt -y dist-upgradeyour kernel is a long way out of date. If you're running on Jessie, you'll need to update to 2018-11-13 Stretch first. – Dougie Dec 09 '18 at 13:54
