Cannot do first update for a straight from raspberrypi.org download of 2017-09-07-raspian-stretch image due to errors:
pi@RWPi:~ $ sudo apt-get update
Ign:1 http://mirrordirector.raspbian.org/raspbian stretch InRelease
Ign:2 http://archive.raspberrypi.org/debian stretch InRelease
Err:3 http://mirrordirector.raspbian.org/raspbian stretch Release
404 Not Found
Err:4 http://archive.raspberrypi.org/debian stretch Release
404 Not Found [IP: 46.235.227.11 80]
Reading package lists... Done
E: The repository 'http://mirrordirector.raspbian.org/raspbian stretch
Release' does no longer have a Release file.
N: Updating from such a repository can't be done securely, and is therefore
disabled by default.
N: See apt-secure(8) manpage for repository creation and user configuration
details.
E: The repository 'http://archive.raspberrypi.org/debian stretch Release'
details.
(Have been chasing this on raspberrypi.org forum but no answers there. Latest post with config info: https://www.raspberrypi.org/forums/viewtopic.php?f=66&t=196666&e=1&view=unread#p1230124
Edit: $ curl -4 http://mirrordirector.raspbian.org/raspbian/dists/stretch/Release
Returns
<?xml version="1.0" encoding="iso-8859-1"?>
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
"http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
<head>
<title>404 - Not Found</title>
</head>
<body>
<h1>404 - Not Found</h1>
</body>
</html>
curl http://mirrordirector.raspbian.org/raspbian/dists/stretch/Release
, do you also get a 404 or the actual file? Digging further up the stack, you can runsudo apt-get update --print-uris
to see if it's somehow using the wrong URL which leads to that 404. – jdonald Nov 03 '17 at 17:11source
packages you can usedeb-src
on it. There are also other posts here on Pi Exchange dealing with mirrordirector problems. – jdonald Nov 04 '17 at 20:09
