I am following this tutorial :
http://www.widriksson.com/raspberry-pi-hadoop-cluster/
I am using Raspberry Pi 3. When I tried to test SSH connection same like the tutorial, I am getting:
ssh: connect to host hadoopmaster port 22: No route to host
Also I don't know if the file /etc/network/interfaces is the right file to put my network configuration :
iface eth0 inet static
address 192.168.0.110
netmask 255.255.255.0
gateway: 192.168.0.1
because It is empty and when I put the IPs in it, I can't connect to wifi anymore.
I tried also to put the static IP cofiguration inside /etc/dhcpcd.conf and I am getting the same above error when I try to open ssh connection.
I also added a host name and IP to /etc/hosts , which is not mentioned in the tutorial, but nothing worked.
hadoopmasterandhadoopMaster? – Technico.top Oct 26 '17 at 10:38sudo pingto the target address? It is quite possible that there is indeed no route to the host. – SDsolar Mar 25 '18 at 05:23
