Is it possible to install software using python.py scripts? I wanted the python script to do a sudo command on the Raspberry Pi. I want the python script to be able to update or install a software in the Raspberry Pi just by running the script.
def index():
    return sudo apt-get update
index()
where in this case the Raspberry Pi will update when I run the script above.
Quintin Balsdon
  • 681
user74911
Try the following:
import subprocess
def index():
    subprocess.call("sudo apt-get update", shell=True)
index()
Quintin Balsdon
  • 681
  • In what ways would this be different or potentially better? I'm trying to learn how to issue commands from within a Python script (see here and here) and having some problems. I wonder if subprocess might be better in my case as well. – uhoh Mar 14 '18 at 08:42
Use the os module for this purpose. Your sudo command is meant to be entered into a terminal and that is what the os.system() function does (it takes your shell command as a string):
import os
def install_function():
    os.system('sudo apt-get update')
install_function()
You probably will still need to enter your passwort.
If you want to return the answer of your shell command, use returnstring=os.popen('<your shell command>'). But be aware that os.popen() does not work with interactive shell.
Sim Son
  • 671
