I have a cluster of Raspberry Pi 3 machines in a cluster. To reduce power consumption I would like to turn off the wireless modules. I have learnt that HDMI can be switched off with the tvservice command:
sudo tvservice -o
Is there a similar command for wifi/bluetooth?
There is a similar question which discusses disabling wifi (Disable WiFi (wlan0) on Pi 3) but it does not specifically request the power conservation aspect which is what I am concerned with.
John Smith
  • 1,251
  • 27
You CAN use device id (which may be appropriate if you had multiple adaptors), but the Foundation recommended method is:-
To turn off wifi, rfkill block wifi; to turn it on, rfkill unblock wifi. For Bluetooth, rfkill block bluetooth and rfkill unblock bluetooth.
Rfkill sounds like what you are after.
$ rfkill list
$ rfkill block (device no)
$ rfkill unblock (device no)
https://askubuntu.com/a/881572/479642
Andy Anderson
  • 638
