I have a Raspberry Pi 3 running the most recent Raspbian distro.
I've installed the most recent go, from the prebuilt package and have it on my path:
$ go version
go version go1.9 linux/arm
However, when I try to install keybase:
$ go get github.com/keybase/client/go/keybase
/usr/local/go/pkg/tool/linux_arm/link: running gcc failed: fork/exec /usr/bin/gcc: cannot allocate memory
I've looked around and tried a few different things, like lowering my ulimit, to no avail. Any clue what I can do to install the most recent version of keybase?
Wayne Werner
  • 461
create a swap file with 4 GB of space: This was my problum when installing docker i had to create a swap file and it worked same error code, so let me know if this works!
Source: This Post
Raspbian uses dphys-swapfile, which is a swap-file based solution instead of the "standard" swap-partition based solution. It is much easier to change the size of the swap.
The configuration file is:
/etc/dphys-swapfile
The content is very simple. By default my Raspbian has 100MB of swap:
CONF_SWAPSIZE=100
If you want to change the size, you need to modify the number and restart dphys-swapfile:
/etc/init.d/dphys-swapfile stop
/etc/init.d/dphys-swapfile start
Edit: On Raspbian the default location is /var/swap, which is (of course) located on the SD card. I think it is a bad idea, so I would like to point out, that the /etc/dphys-swapfile can have the following option too:
CONF_SWAPFILE=/media/btsync/swapfile
I only problem with it, the usb storage is automounted, so a potential race here (automount vs. swapon)
User98764431
  • 569
