I've read several threads out there regarding Raspbian WiFi connectivity problems. I've solved many of my problems, but I'm not figuring out why (or how?) I can't restart WiFi.
Upon reboot, WiFi is connected fine, I just can't manually restart it.
The Problem
$ sudo ifdown wlan0
ifdown: interface wlan0 not configured
$ sudo ifup wlan0 --force -v
ifup: reading directory /etc/network/interfaces.d
ifup: parsing file /etc/network/interfaces.d/lo
ifup: parsing file /etc/network/interfaces.d/wlan0
ifup: configuring interface wlan0=wlan0 (inet)
/bin/run-parts --exit-on-error --verbose /etc/network/if-pre-up.d
run-parts: executing /etc/network/if-pre-up.d/wireless-tools
run-parts: executing /etc/network/if-pre-up.d/wpasupplicant
wpa_supplicant: wpa-driver nl80211,wext (default)
wpa_supplicant: /sbin/wpa_supplicant -s -B -P /run/wpa_supplicant.wlan0.pid -i wlan0 -D nl80211,wext -c /etc/wpa_supplicant/wpa_supplicant.conf
Starting /sbin/wpa_supplicant...
wpa_supplicant: /sbin/wpa_supplicant daemon failed to start
run-parts: /etc/network/if-pre-up.d/wpasupplicant exited with return code 1
ifup: failed to bring up wlan0
After reading some of the logs I found that there are state files in /var/run/network/ifstate.wlan0 and /var/run/wpa_supplicant/wlan0.
Is this correct? Perhaps in wpa_supplicant.conf file I'm pointing ctrl_interface to the wrong place?
What are the different purposes of those two different wlan0 state files?
What is the correct way to restart networking without reboot?
My Configurations:
$ ifconfig -a
loop txqueuelen 1 (Loopback Local)
RX packets 400 bytes 118100 (115.3 KiB)
TX packets 400 bytes 118100 (115.3 KiB)
wlan0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.104 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 fe80::e9c2:462e:7e58:2755 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:81:62:76 txqueuelen 1000 (Ethernet)
RX packets 5027 bytes 6582631 (6.2 MiB)
TX packets 2057 bytes 273735 (267.3 KiB)
$ iwconfig wlan0
wlan0 IEEE 802.11 ESSID:"MySSID"
Mode:Managed Frequency:2.412 GHz Access Point: 84:16:F9:FC:36:54
Bit Rate=65 Mb/s Tx-Power=31 dBm
Retry short limit:7 RTS thr:off Fragment thr:off
Power Management:off
Link Quality=70/70 Signal level=-28 dBm
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
$ cat /etc/wpa_supplicant/wpa_supplicant.conf
update_config=1
network={
ssid="MySSID"
psk="MyPassword"
$ cat /etc/network/interfaces
$ ls -la /etc/network/interfaces.d
total 16
drwxr-xr-x 2 root root 4096 set 25 17:33 .
drwxr-xr-x 7 root root 4096 set 25 15:15 ..
-rw-r--r-- 1 root root 31 ago 31 19:44 lo
-rw-r--r-- 1 root root 95 set 25 15:10 wlan0
$ cat /etc/network/interfaces.d/lo
auto lo
iface lo inet loopback
$ cat /etc/network/interfaces.d/wlan0
allow-hotplug wlan0
iface wlan0 inet dhcp
wireless-power off
dhcpwill disable the default network managerdhcpcdand decrease robustness. Put the settings back to those in How do I set up networking/WiFi/Static IP which work for everyone else. THEN explain WHY you think "WiFi is off" – Milliways Sep 25 '17 at 23:54dhcpandmanualconfigurations are adequate for my scenario, what other option there is? – ffleandro Sep 26 '17 at 19:56
