I'm puzzling over the network configuration in Stretch with dhcpcd. The ethernet connection works fine. WiFi is detected but it doesn't try to connect at all. Surely I'm missing an obvious step...
/etc/wpa_supplicant/wpa_supplicant.conf
country=IT
ap_scan=1
update_config=1
network={
ssid="---"
psk="---"
key_mgmt=WPA-PSK
/etc/dhcpcd.conf
hostname
clientid
persistent
noarp
option rapid_commit
option ntp_servers
option interface_mtu
slaac private
profile static_eth0
static ip_address=192.168.1.200/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
interface eth0
fallback static_eth0
interface wlan0
static ip_address=192.168.178.222/24
static routers=192.168.178.1
static domain_name_servers=192.168.178.1
$lsusb
Bus 001 Device 005: ID 0bda:8179 Realtek Semiconductor Corp. RTL8188EUS 802.11n Wireless Network Adapter
$dmesg | tail
[ 4.921791] r8188eu: module is from the staging directory, the quality is unknown, you have been warned.
[ 5.004467] Chip Version Info: CHIP_8188E_Normal_Chip_TSMC_D_CUT_1T1R_RomVer(0)
[ 5.147308] usbcore: registered new interface driver r8188eu
[ 5.317772] rtc-ds1307 1-0068: rtc core: registered ds1307 as rtc0
[ 5.317829] rtc-ds1307 1-0068: 56 bytes nvram
[ 6.222872] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
[ 6.223792] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 6.925950] MAC Address = f4:f2:6d:1c:f8:64
[ 6.930023] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
[ 7.755753] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.757473] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC5E1
[ 26.332142] random: crng init done
$ifconfig
inet 192.168.178.73 netmask 255.255.255.0 broadcast 192.168.178.255
inet6 fe80::2a22:1789:bfb0:6a48 prefixlen 64 scopeid 0x20<link>
ether b8:27:eb:33:e9:1e txqueuelen 1000 (Ethernet)
RX packets 848 bytes 58502 (57.1 KiB)
TX packets 766 bytes 131138 (128.0 KiB)
inet6 fe80::24b:5bfc:8a9e:b148 prefixlen 64 scopeid 0x20<link>
loop txqueuelen 1 (Local Loopback)
RX packets 25 bytes 7740 (7.5 KiB)
TX packets 25 bytes 7740 (7.5 KiB)
wlan0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether f4:f2:6d:1c:f8:64 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
$iwconfig
eth0 no wireless extensions.
lo no wireless extensions.
wlan0 unassociated Nickname:"<WIFI@REALTEK>"
Mode:Auto Frequency=2.412 GHz Access Point: Not-Associated
Sensitivity:0/0
Retry:off RTS thr:off Fragment thr:off
Power Management:off
Link Quality:0 Signal level:0 Noise level:0
Rx invalid nwid:0 Rx invalid crypt:0 Rx invalid frag:0
Tx excessive retries:0 Invalid misc:0 Missed beacon:0
$ ps aux | grep wpa
root 309 0.0 0.4 9552 4028 ? Ss 18:30 0:00 /sbin/wpa_supplicant -u -s -O /run/wpa_supplicant
Which log should I check?
sudo iwlist wlan0 scan
? This command if working will show the SSID's visible by your WiFi network card in the Raspberry Pi. – MatsK Sep 10 '17 at 17:59
