Yesterday I bought a Raspberry Pi 3, and I tried to enable WLAN on it. This did not work.
Now I can't access the Raspberry Pi over SSH because it's always trying to connect to my router.
Is there a way to reset the WLAN configuration without a display?
Aurora0001
  • 6,308
  • 38
Killoso32
At the first boot after being created, Raspbian will check for two files in the boot partition.
ssh
If the file ssh is there it will enable ssh login. OBS the file is empty and has no extension.
And the file wpa_supplicant.conf with the content:
network={
    ssid="YourWiFiSSID"
    psk="YourWiFiPassword"
    key_mgmt=WPA-PSK
So create a fresh Raspbian SD card and create the two files ssh and wpa_supplicant.conf with WiFi credential and of you go.
MatsK
  • 2,791
