Deluge have no init scripts in raspberry pi repository?
root@rpi ~# service deluged start
deluged: unrecognized service
root@rpi ~# service deluge-web
deluge-web: unrecognized service
But deluged and deluge-web are installed :(,
sudo wget https://gist.github.com/earthmeLon/a4bf68d385f8f840d2b5/raw/ -O /etc/init.d/deluged
sudo chmod +x /etc/init.d/deluged
sudo update-rc.d deluged defaults
sudo update-rc.d deluged enable
#!/bin/sh
### BEGIN INIT INFO
# Provides: deluged
# Required-Start: $local_fs $remote_fs
# Required-Stop: $local_fs $remote_fs
# Should-Start: $network
# Should-Stop: $network
# Default-Start: 2 3 4 5
# Default-Stop: 0 1 6
# Short-Description: Start or stop the Deluge BitTorrent daemon.
# Description: Start or stop the Deluge BitTorrent daemon.
### END INIT INFO
Authors: Tanguy Ortolo <tanguy+debian@ortolo.eu>,
Cristian Greco <cristian@regolo.cc>
PATH=/sbin:/usr/sbin:/bin:/usr/bin
DESC="Deluge BitTorrent Daemon"
NAME="deluged"
DAEMON=/usr/bin/$NAME
DAEMON_ARGS="-d -c /var/lib/deluged/config -l /var/log/deluged/daemon.log -L info"
USER=debian-deluged
MASK=0027
PIDFILE=/var/run/$NAME.pid
SCRIPTNAME=/etc/init.d/$NAME
Exit if the package is not installed
[ -x "$DAEMON" ] || exit 0
ENABLE_DELUGED=1
Read configuration variable file if it is present
[ -r /etc/default/$NAME ] && . /etc/default/$NAME
Load the VERBOSE setting and other rcS variables
[ -f /etc/default/rcS ] && . /etc/default/rcS
Define LSB log_* functions.
Depend on lsb-base (>= 3.0-6) to ensure that this file is present
and status_of_proc is working.
. /lib/lsb/init-functions
Function that starts the daemon/service
do_start()
if [ $ENABLE_DELUGED != 1 ]; then
log_progress_msg "Not starting ${DESC} ${NAME}, disabled in /etc/default/${NAME}"
else
# Return
# 0 if daemon has been started
# 1 if daemon was already running
# 2 if daemon could not be started
start-stop-daemon --start --background --quiet --pidfile $PIDFILE --exec $DAEMON
--chuid $USER --umask $MASK --test > /dev/null
|| return 1
start-stop-daemon --start --background --quiet --pidfile $PIDFILE --make-pidfile --exec $DAEMON \
--chuid $USER --umask $MASK -- $DAEMON_ARGS \
|| return 2
fi
Function that stops the daemon/service
do_stop()
Return
0 if daemon has been stopped
1 if daemon was already stopped
2 if daemon could not be stopped
other if a failure occurred
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --pidfile $PIDFILE
RETVAL="$?"
[ "$RETVAL" = "2" ] && return 2
rm -f $PIDFILE
return "$RETVAL"
case "$1" in
start)
[ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME"
do_start
case "$?" in
0|1) [ "$VERBOSE" != no ] && log_end_msg 0 ;;
2) [ "$VERBOSE" != no ] && log_end_msg 1 ;;
esac
stop)
[ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME"
do_stop
case "$?" in
esac
status)
status_of_proc "$DAEMON" "$NAME" && exit 0 || exit $?
restart|force-reload)
log_daemon_msg "Restarting $DESC" "$NAME"
do_stop
case "$?" in
0|1)
do_start
case "$?" in
0) log_end_msg 0 ;;
1) log_end_msg 1 ;; # Old process is still running
) log_end_msg 1 ;; # Failed to start
esac
# Failed to stop
log_end_msg 1
esac
echo "Usage: $SCRIPTNAME {start|stop|status|restart|force-reload}" >&2
exit 3
esac
It has been brought to my attention via comments of this answer that this init script does not work with deluge's webui. Please look at the documentation at deluge's website for further information. The following is their script:
#!/bin/sh
### BEGIN INIT INFO
# Provides: deluge-daemon
# Short-Description: Daemonized version of deluge and webui.
# Description: Starts the deluge daemon with the user specified in
# /etc/default/deluge-daemon.
### END INIT INFO
Author: Adolfo R. Brandes
Updated by: Jean-Philippe "Orax" Roemer
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
DESC="Deluge Daemon"
NAME1="deluged"
NAME2="deluge"
DAEMON1=/usr/bin/deluged
DAEMON1_ARGS="-d" # Consult man deluged
for more options
DAEMON2=/usr/bin/deluge-web
DAEMON2_ARGS="" # Consult man deluge-web
for more options
PIDFILE1=/var/run/$NAME1.pid
PIDFILE2=/var/run/$NAME2.pid
UMASK=022 # Change this to 0 if running deluged as its own user
PKGNAME=deluge-daemon
SCRIPTNAME=/etc/init.d/$PKGNAME
[ -x "$DAEMON1" -a -x "$DAEMON2" ] || exit 0
[ -r /etc/default/$PKGNAME ] && . /etc/default/$PKGNAME
Depend on lsb-base (>= 3.0-6) to ensure that this file is present.
if [ -z "$RUN_AT_STARTUP" -o "$RUN_AT_STARTUP" != "YES" ]
then
log_warning_msg "Not starting $PKGNAME, edit /etc/default/$PKGNAME to start it."
exit 0
fi
if [ -z "$DELUGED_USER" ]
then
log_warning_msg "Not starting $PKGNAME, DELUGED_USER not set in /etc/default/$PKGNAME."
exit 0
fi
Function to verify if a pid is alive
is_alive()
pid=cat $1
> /dev/null 2>&1
kill -0 $pid > /dev/null 2>&1
return $?
do_start()
Return
is_alive $PIDFILE1
RETVAL1="$?"
if [ $RETVAL1 != 0 ]; then
rm -f $PIDFILE1
start-stop-daemon --start --background --quiet --pidfile $PIDFILE1 --make-pidfile
--exec $DAEMON1 --chuid $DELUGED_USER --user $DELUGED_USER --umask $UMASK -- $DAEMON1_ARGS
RETVAL1="$?"
else
is_alive $PIDFILE2
RETVAL2="$?"
[ "$RETVAL2" = "0" -a "$RETVAL1" = "0" ] && return 1
fi
is_alive $PIDFILE2
RETVAL2="$?"
if [ $RETVAL2 != 0 ]; then
sleep 2
rm -f $PIDFILE2
start-stop-daemon --start --background --quiet --pidfile $PIDFILE2 --make-pidfile
--exec $DAEMON2 --chuid $DELUGED_USER --user $DELUGED_USER --umask $UMASK -- $DAEMON2_ARGS
RETVAL2="$?"
fi
[ "$RETVAL1" = "0" -a "$RETVAL2" = "0" ] || return 2
do_stop()
Return
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --user $DELUGED_USER --pidfile $PIDFILE2
RETVAL2="$?"
start-stop-daemon --stop --quiet --retry=TERM/30/KILL/5 --user $DELUGED_USER --pidfile $PIDFILE1
RETVAL1="$?"
[ "$RETVAL1" = "2" -o "$RETVAL2" = "2" ] && return 2
rm -f $PIDFILE1 $PIDFILE2
[ "$RETVAL1" = "0" -a "$RETVAL2" = "0" ] && return 0 || return 1
case "$1" in
start)
[ "$VERBOSE" != no ] && log_daemon_msg "Starting $DESC" "$NAME1"
do_start
case "$?" in
esac
stop)
[ "$VERBOSE" != no ] && log_daemon_msg "Stopping $DESC" "$NAME1"
do_stop
case "$?" in
esac
log_daemon_msg "Restarting $DESC" "$NAME1"
do_stop
case "$?" in
0|1)
do_start
case "$?" in
0) log_end_msg 0 ;;
esac
# Failed to stop
log_end_msg 1
esac
echo "Usage: $SCRIPTNAME {start|stop|restart|force-reload}" >&2
exit 3
esac
Nope, deluge does not have init scripts in current debian, as well as in ubuntu and a bunch of other Linuxes. They have guides on creating such scripts though: http://dev.deluge-torrent.org/wiki/UserGuide/InitScript (and one especially for debian&ubuntu). It should not be that hard, but I switched to transmission because of this extra work.
That seems to be an (old) outstanding issue: http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=541138
You might try the version from Debian Expirimental, see:
http://wiki.debian.org/DebianExperimental and http://packages.debian.org/search?suite=experimental&searchon=names&keywords=deluged
