I have recently started working on ad-hoc connection of Raspberry Pi 3. I am having difficulties creating an ad-hoc connection between windows 8 or 10 pc and the Raspberry Pi 3. I`ve tried to configure my RPi 3 ad-hoc as saying on this link Ad Hoc setup in RPi 3 and my configured code is shown below;
/etc/network/interfaces at RPi 3:
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet static
    address 10.1.1.38
    netmask 255.255.255.0
    wireless-mode ad-hoc
    wireless-essid PiAdHocnet
    wireless-channel 1
    # wpa-conf /etc/wpa_supplicant/wpa_supplicant.conf
iface default inet dhcp
allow-hotplug wlan1
iface wlan1 inet manual
After this configuration, I reboot RP 3 and also reset wifi as
sudo ifdown wlan0
sudo ifup wlan0
then ad-hoc connection appears on windows 10 computer' s wifi list but when I try to connect, it says "can not connect to this network". cannot seem to find a solution to this problem, and no other documentation that I have read has contained any helpful information. Can you help me how can I connect my windows 8 or 10 computer to Raspberry Pi 3 ad-hoc?
When I follow instruction in this link and changed address 10.1.1.38 with address 192.168.1.1 and wireless-essid PiAdHocnet with wireless-essid RasbiNet, somehow I can connect to RPi 3 ad-hoc network by iPhone 5S
Bahadirhan Keles
  • I figured out how to connect RPi 3 ad-hoc network from windows 8 and 10. After my last modification (changed address 10.1.1.38 with address 192.168.1.1 and wireless-essid PiAdHocnet with wireless-essid and RasbiNet), I gave 192.168.1.3 IP to my wifi. Wireless network picker in Windows 8 and 10 doesn't show ad-hoc networks, connecting must be done by hand. For connect to an ad-hoc WiFi network in Windows follow this link – Bahadirhan Keles Aug 02 '17 at 18:40
Without a DHCPv4 server running on your Pi Windows usually will be very sad. So sad. The ISC DHCPv4 server can be easily installed, from package isc-dhcp-server. Make sure to adapt its config file to reference the IPv4 subnet you have assigned to wlan0 where your AP is.
TheDiveO
  • 1,591
