I am trying to configure my Docker Swarm Cluster and need to have the following ports open so that my cluster can communicate and operate correctly:
- TCP port 2377
- TCP port and UDP port 7946
- UDP port 4789
How do I open these ports?
I believe this is the issue that are causing my worker node to be DOWN
sudo iptables --listwill show you the open ports. From what I have read here and here, the raspberry Pi does not have any firewall rules in place by default, so the problem is more likey to be with the other devices in question. – otoomey Jul 26 '17 at 21:49
