I am setting up Raspbian Jessie on a Raspberry Pi 2 B+ board and experiencing problems with configuring a static IP. At this point I've spent about half a day googling the problem and it would seem that I'm not the only one having issues with this. Unfortunately the responses to the posts I've found all seem to say the same thing; either don't modify /etc/network/interfaces and configure your static IP through /etc/dhcpcd.conf or disable dhcpcd and configure this through /etc/network/interfaces. I've tried both methods (for reference this article had the most complete instruction: How do I set up networking/WiFi/static IP address? ) and neither method works. Adding the static IP using either process results in a network setup that can access other machines on the same LAN segment but nothing past the gateway router. My question here is how do I resolve this problem so that I can use a static IP without loosing internet access?
Details:
If the network files (/etc/network/interfaces & /etc/dhcpcd.conf) are left alone after a clean install of Raspbian Jessie than the network connection works as expected using DHCP. Output from the ifconfig command showing this setup is below:
$ ifconfig
eth0 Link encap:Ethernet HWaddr b8:27:eb:85:61:60
inet addr:192.168.1.165 Bcast:192.168.1.255 Mask:255.255.255.0
inet6 addr: fe80::da73:8269:d6f0:5728/64 Scope:Link
RX packets:28139 errors:0 dropped:0 overruns:0 frame:0
TX packets:609 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:2253500 (2.1 MiB) TX bytes:127490 (124.5 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:200 errors:0 dropped:0 overruns:0 frame:0
TX packets:200 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:16656 (16.2 KiB) TX bytes:16656 (16.2 KiB)
Attempting to ping an internet address like google.com also works:
$ ping -c 3 google.com
PING google.com (172.217.12.78) 56(84) bytes of data.
64 bytes from dfw28s05-in-f14.1e100.net (172.217.12.78): icmp_seq=1 ttl=53 time=32.9 ms
64 bytes from dfw28s05-in-f14.1e100.net (172.217.12.78): icmp_seq=2 ttl=53 time=49.6 ms
64 bytes from dfw28s05-in-f14.1e100.net (172.217.12.78): icmp_seq=3 ttl=53 time=33.3 ms
--- google.com ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 32.982/38.657/49.625/7.759 ms
Output from the route command at this time is as follows:
$ route
Kernel IP routing table
default 192.168.1.1 0.0.0.0 UG 202 0 0 eth0
192.168.1.0 * 255.255.255.0 U 202 0 0 eth0
Also if I run the 'traceroute' command under this configuration I get the following (clipped to just the top few results for comparison with a later traceroute run):
$ traceroute google.com
traceroute to google.com (172.217.6.142), 30 hops max, 60 byte packets
1 192.168.1.1 (192.168.1.1) 0.644 ms 0.426 ms 0.503 ms
2 96.120.17.93 (96.120.17.93) 9.263 ms 15.719 ms 14.508 ms
3 68.85.252.217 (68.85.252.217) 15.308 ms 15.187 ms 15.211 ms
4 68.85.246.169 (68.85.246.169) 15.095 ms 14.974ms 14.995 ms
5 68.85.87.245 (68.85.87.245) 16.865 ms 15.714 ms 16.622 ms
Next I try to change the networking configuration to use a static IP. This is done by adding the lines below to the end of the /etc/dhcpcd.conf file (NO changes were made to /etc/network/interfaces):
interface eth0
static ip_address=192.168.1.20/24
static routers=192.168.1.1
static domain_name_servers=192.168.1.1
After making these changes I reboot the raspberry pi and upon restart I have a functioning network configuration that will ONLY allow connections to a computer on my LAN. Below is the ifconfig output after changing to use the static IP.
$ ifconfig
inet addr:192.168.1.20 Bcast:192.168.1.255 Mask:255.255.255.0
RX packets:689 errors:0 dropped:0 overruns:0 frame:0
TX packets:70 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:57073 (55.7 KiB) TX bytes:12174 (11.8 KiB)
RX packets:72 errors:0 dropped:0 overruns:0 frame:0
TX packets:72 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:6288 (6.1 KiB) TX bytes:6288 (6.1 KiB)
Here I ping the gateway router (192.168.1.1) and another Debian machine on the same LAN segment (192.168.1.9); both machines can be reached:
$ ping -c 3 192.168.1.1
PING 192.168.1.1 (192.168.1.1) 56(84) bytes of data.
64 bytes from 192.168.1.1: icmp_seq=1 ttl=64 time=0.764 ms
64 bytes from 192.168.1.1: icmp_seq=2 ttl=64 time=0.652 ms
64 bytes from 192.168.1.1: icmp_seq=3 ttl=64 time=0.636 ms
--- 192.168.1.1 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2098ms
rtt min/avg/max/mdev = 0.636/0.684/0.764/0.056 ms
$ ping -c 3 192.168.1.9
PING 192.168.1.9 (192.168.1.9) 56(84) bytes of data.
64 bytes from 192.168.1.9: icmp_seq=1 ttl=64 time=1.06 ms
64 bytes from 192.168.1.9: icmp_seq=2 ttl=64 time=0.536 ms
64 bytes from 192.168.1.9: icmp_seq=3 ttl=64 time=0.532 ms
--- 192.168.1.9 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2012ms
rtt min/avg/max/mdev = 0.532/0.710/1.064/0.251 ms
However once I try to ping something that is on a different network segment (Google in this case) I can't reach it.
PING google.com (172.217.6.142) 56(84) bytes of data.
From 192.168.1.1 icmp_seq=1 Destination Port Unreachable
From 192.168.1.1 icmp_seq=2 Destination Port Unreachable
From 192.168.1.1 icmp_seq=3 Destination Port Unreachable
3 packets transmitted, 0 received, +3 errors, 100% packet loss, time 2053ms
The issue does not appear to be related to DNS as I can resolve host strings just fine:
$ nslookup google.com
Server: 192.168.1.1
Address: 192.168.1.1#53
Non-authoritative answer:
Address: 172.217.12.78
Here are outputs from the 'route' and 'traceroute' commands. Notice that something funny is happening with traceroute as it only goes as far as the gateway router now:
$ route
traceroute to google.com (172.217.12.78), 30 hops max, 60 byte packets
1 192.168.1.1 (192.168.1.1) 0.732 ms 0.581 ms 0.482 ms
2 192.168.1.1 (192.168.1.1) 0.590 ms 0.497 ms 0.625 ms
The network configuration I added to /etc/dhcpcd.conf is also in use by two other Ubuntu machines that are on the same LAN segment; neither of these machines has any difficulty accessing the internet through the gateway router.
If anyone can shed some light on what is causing this issue and how I can resolve it I would appreciate their insight. Thanks!
Additional Info:
Raspbian Image: 2017-07-05-raspbian-jessie.zip
File: /etc/dhcpcd.conf (following static IP update):
#controlgroup wheel
# Inform the DHCP server of our hostname for DDNS.
hostname
# Use the hardware address of the interface for the Client ID.
clientid
# or
# Use the same DUID + IAID as set in DHCPv6 for DHCPv4 ClientID as per RFC4361.
#duid
# Persist interface configuration when dhcpcd exits.
persistent
# Rapid commit support.
# Safe to enable by default because it requires the equivalent option set
# on the server to actually work.
option rapid_commit
# A list of options to request from the DHCP server.
# Most distributions have NTP support.
option ntp_servers
# Respect the network MTU.
# Some interface drivers reset when changing the MTU so disabled by default.
#option interface_mtu
# A ServerID is required by RFC2131.
# Generate Stable Private IPv6 Addresses instead of hardware based ones
slaac private
# A hook script is provided to lookup the hostname if not set by the DHCP
# server, but it should not be run by default.
nohook lookup-hostname
interface eth0
File: /etc/network/interfaces:
auto lo
iface lo inet loopback
iface eth0 inet manual
allow-hotplug wlan0
iface wlan0 inet manual
allow-hotplug wlan1
iface wlan1 inet manual
