How can I read the status of the on board red led in raspberry 3.0 model B? Thank you
The red LED is the power LED. If any code is running at all, you can assume that this LED is on. – stevieb Jul 07 '17 at 13:07
In raspberry 3 when voltage in lower than 4.65 Voltage red led turns off. So I would like to detect voltage drops using the value of this LED – hmmy92 Jul 07 '17 at 13:23
Ok, fair enough :) – stevieb Jul 07 '17 at 13:28
In case GPIO 35 is confusing, it does not have a breakout pin but you can still read its state normally (using the BCM numbering). – goldilocks Jul 07 '17 at 14:01
Thanks for your reply, I am using Raspberry Pi 3 Model B Rev 1.2 how can I read the status of this pin? As I have seen pi3 is not supporting detection of under-voltage using this pin. Am I wrong? – hmmy92 Jul 07 '17 at 14:13
Please do not bother asking how to read the state of a GPIO on a Raspberry Pi. This must have been regurgitated here and elsewhere on the internet literally thousands of times. You might as well ask other people to do basic arithmetic for you ("Please, what is 3 + 5?") when there is a calculator in your hand. Use a search engine. – goldilocks Jul 07 '17 at 14:59
I know how to read the state of a GPIO but GPIO 35 is not working so I asked if somebody else has tried something different – hmmy92 Jul 07 '17 at 17:17
@goldilocks the supposed duplicate refers to Pi2. On the Pi3 the power is connected to a port expander. The question is a duplicate, see Raspberry Pi Power Limitations which has some comments. There are other answers (how DO you find duplicates you know are there) – Milliways Jul 08 '17 at 00:08
@Milliways You're right; someone here implies because of this it's not possible, although the end of your answer implies there is. I don't see this as a duplicate of that though. – goldilocks Jul 08 '17 at 13:09
Current kernels have the board LEDs in /sys/device/platform/leds/leds
. There are two; in each subdirectory you will find a uevent
node with some information. led0
is evidently the green ACT light:
OF_NAME=act
OF_FULLNAME=/leds/act
OF_COMPATIBLE_N=0
And led1
is the red PWR light:
OF_NAME=pwr
OF_FULLNAME=/leds/pwr
OF_COMPATIBLE_N=0
Note these names correspond to another sysfs directory, /sys/firmware/devicetree/leds
-- but the information there does not look pertinent. However, in the same directory as uevent
there is brightness
, which apparently has a range of 0-255; normally when running it's 255. Although that node is writable, trying to change the value has no effect. But reading its state is obviously possible.
- 58,859
- 17
- 112
- 227
Your question is ambiguous.
If you want to determine the low voltage state, you can do this by reading the state through a mailbox interface. I have used the following c code:-
https://raspberrypi.stackexchange.com/a/54328/8697
Other code described in https://raspberrypi.stackexchange.com/a/44177/8697 may also make it possible, but untested.
If you just want to read LED status /sys/devices/platform/leds/leds/led1
seems to work; whether this also reflects the low voltage state is unknown (and AFAIK) undocumented. It is certainly possible to extinguish the LED by writing 0
to brightness
Examination of the Pi3 circuitry (which differs from earlier models) seems to indicate that if the voltage is Low the LED will ALWAYS be off.
I have not explored what the impact of writing to /sys/devices/platform/leds/leds/led1
is on the rpi3-gpiovirtbuf
. GPIO can be input OR output (but who knows about the expander), so they may be incompatible functions.
Testing low voltage is a non-trivial task.
- 59,890
- 31
- 101
- 209
Thank you for your reply, I tested the code you suggested and unfortunately didn't work. It returns always "Get state of 135 as 0" despite there is or not under-voltage. Finally, I checked for the directory but there is no folder leds on /sys/device/platform – hmmy92 Jul 11 '17 at 08:29
The code worked last time I tried it. As I stated testing low voltage is a non-trivial task. If you don't have led1 you don't have the latest 4.9.35 kernel. – Milliways Jul 11 '17 at 12:35
