so I've read around forums that the max current from a RPi 3.3v GPIO pin is 50 mA, but since it is the max I don't know if I should take a resistor for 50 mA or for a lower current.
Iliyan
You have been misinformed.
The 50 mA is for the GPIO as a whole. (This applies to the original Pi A & B; the B+ and later (with 40 pin header), including the Pi Zero, have no such limit.)
It is generally suggested that you don't try to draw more than 16 mA from a single GPIO (although the 16 mA figure is actually how much can be drawn before the GPIO can't reliably signal a logical high).
You need to expand your question to explain what you want to do if you want a useful answer.
joan
  • 71,024
  • 73
  • 106
  • OK, but for example, if you write a simple program to turn on an led, the GPIO pin sends all of the 16mA? – Iliyan Jul 04 '17 at 15:59
  • The GPIO will send as much as it can, which can be a lot more than 16 mA (perhaps even more than 50 mA). Normally the thing you connect will have a resistance to limit the current. In the case of a LED it has no resistance so it needs a resistor in series to prevent the LED burning out. – joan Jul 04 '17 at 16:43
