I'm trying enable cryptographic device acceleration on Raspberry Pi 2B. Here's a results of benchmarks:
hubot@hubot-vps:~ $ cryptsetup benchmark
# Tests are approximate using memory only (no storage IO).
PBKDF2-sha1 131072 iterations per second
PBKDF2-sha256 49648 iterations per second
PBKDF2-sha512 11497 iterations per second
PBKDF2-ripemd160 64250 iterations per second
PBKDF2-whirlpool 6147 iterations per second
# Algorithm | Key | Encryption | Decryption
aes-cbc 128b 13.6 MiB/s 14.5 MiB/s
serpent-cbc 128b N/A N/A
twofish-cbc 128b N/A N/A
aes-cbc 256b 10.7 MiB/s 11.2 MiB/s
serpent-cbc 256b N/A N/A
twofish-cbc 256b N/A N/A
aes-xts 256b 13.9 MiB/s 14.2 MiB/s
serpent-xts 256b N/A N/A
twofish-xts 256b N/A N/A
aes-xts 512b 10.9 MiB/s 11.0 MiB/s
serpent-xts 512b N/A N/A
twofish-xts 512b N/A N/A
hubot@hubot-vps:~ $ openssl speed -elapsed -evp aes-128-cbc
You have chosen to measure elapsed time instead of user CPU time.
Doing aes-128-cbc for 3s on 16 size blocks: 3407812 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 979572 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 253933 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 64082 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 8032 aes-128-cbc's in 3.01s
OpenSSL 1.0.1t 3 May 2016
built on: Fri Jan 27 22:44:27 2017
options:bn(64,32) rc4(ptr,char) des(idx,cisc,16,long) aes(partial) blowfish(ptr)
compiler: gcc -I. -I.. -I../include -fPIC -DOPENSSL_PIC -DOPENSSL_THREADS -D_REENTRANT -DDSO_DLFCN -DHAVE_DLFCN_H -DL_ENDIAN -DTERMIO -g -O2 -fstack-protector-strong -Wformat -Werror=format-security -D_FORTIFY_SOURCE=2 -Wl,-z,relro -Wa,--noexecstack -Wall -DOPENSSL_BN_ASM_MONT -DOPENSSL_BN_ASM_GF2m -DSHA1_ASM -DSHA256_ASM -DSHA512_ASM -DAES_ASM -DGHASH_ASM
The 'numbers' are in 1000s of bytes per second processed.
type 16 bytes 64 bytes 256 bytes 1024 bytes 8192 bytes
aes-128-cbc 18175.00k 20897.54k 21668.95k 21873.32k 21859.85k
hubot@hubot-vps:~ $ OPENSSL_ia32cap="~0x200000200000000" openssl speed -elapsed -evp aes-128-cbc
Doing aes-128-cbc for 3s on 16 size blocks: 3378239 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 64 size blocks: 978479 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 256 size blocks: 253871 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 1024 size blocks: 64078 aes-128-cbc's in 3.00s
Doing aes-128-cbc for 3s on 8192 size blocks: 8028 aes-128-cbc's in 3.00s
aes-128-cbc 18017.27k 20874.22k 21663.66k 21871.96k 21921.79k
I'm following this tutorial: https://lauri.võsandi.com/2014/07/cryptodev.html#cryptodev-linux. I first built dependencies for openssl package using command $ sudo apt-get build-dep openssl. Next, I fetch source by $ sudo apt-get source openssl. I moved into ~/openssl-1.0.1t directory. I executed following command in terminal:
sed -i -e "s/CONFARGS =/CONFARGS = -DHAVE_CRYPTODEV -DUSE_CRYPTODEV_DIGESTS/" debian/rules
dch -i "Enabled cryptodev support"
Next, I tried build package openssl with enabled cryptodev support using debuild tool and I got following error:
eng_cryptodev.c:56:31: fatal error: crypto/cryptodev.h: No such file or directory
# include <crypto/cryptodev.h>
compilation terminated.
Makefile:77: recipe for target 'depend' failed
make[3]: *** [depend] Error 1
make[3]: Leaving directory '/home/hubot/openssl-1.0.1t/crypto/engine'
Makefile:133: recipe for target 'depend' failed
make[2]: *** [depend] Error 1
make[2]: Leaving directory '/home/hubot/openssl-1.0.1t/crypto'
Makefile:472: recipe for target 'depend' failed
make[1]: *** [depend] Error 1
make[1]: Leaving directory '/home/hubot/openssl-1.0.1t'
debian/rules:49: recipe for target 'build-stamp' failed
make: *** [build-stamp] Error 2
dpkg-buildpackage: error: debian/rules build gave error exit status 2
debuild: fatal error at line 1376:
dpkg-buildpackage -rfakeroot -D -us -uc failed
So I thought that I have unmet dependency and cryptodev package is missing, thus I decided to manually compile it.
I fetched cryptodev source from http://nwl.cc/pub/cryptodev-linux/cryptodev-linux-1.9.tar.gz to directory ~/cryptodev, I unpacked tar archive and I entered into ~/cryptodev/cryptodev-linux-1.9 directory. I followed instructions on https://github.com/cryptodev-linux/cryptodev-linux/blob/master/INSTALL and I enter make command and I got below error:
hubot@hubot-vps:~/cryptodev/cryptodev-linux-1.9 $ make
make -C /lib/modules/4.9.24-v7+/build M=/home/hubot/cryptodev/cryptodev-linux-1.9 modules
make[1]: *** /lib/modules/4.9.24-v7+/build: No such file or directory. Stop.
Makefile:27: recipe for target 'build' failed
make: *** [build] Error 2
I stopped at this error and I do not know what should I do next. I count on help. Thank you in advance.
